Old 06-28-2012, 09:55 PM   #1
xMasterJPx
xMasterJPx is on a distinguished road
xMasterJPx's Avatar
2000 SC1
Attention 2000 Saturn SC1 High Idle when parked!!! Need help!
Ok so lately my RPM's have jumped over 2000 when I park my car and it started happening about 2 weeks ago and now it's happening more often as i drive and then park. if I just start my car, my RPM's are normal!
Any idea what may be the problem? I'm gonna be cleaning my throttle body cause idk if it's ever been clean and my car is sitting at a 140K, but I don't want my car to fail on me because of this! Can anyone help me out in figuring out how to fix this issue?
xMasterJPx is offline   Reply With Quote
Old 06-28-2012, 10:09 PM   #2
martensitic
martensitic is on a distinguished road
1996 SL1
Default Re: 2000 Saturn SC1 High Idle when parked!!! Need help!
I had the same symptom and it turned out to be a bad throttle position sensor (TPS). Any trouble codes on the computer?
Throttle body cleaning also won't hurt while you're in there.
1996 Saturn SL1 SOHC, A/T, 116k, NYC
martensitic is offline   Reply With Quote
Old 06-28-2012, 10:34 PM   #3
xMasterJPx
xMasterJPx's Avatar
2000 SC1
no not at all, funny thing is, I'm getting no engine light, oil light nothing!
i'm also gonna be doing a seafoam clean up this weekend as well!
Old 06-28-2012, 10:44 PM   #4
ssewall
ssewall is on a distinguished road
When it happens, turn the car off, then on again. If this fixes the problem your TPS is faulty.
ssewall is offline   Reply With Quote
Old 06-28-2012, 10:46 PM   #5
xMasterJPx
xMasterJPx's Avatar
2000 SC1
good thing the sensors cost only $40 if that's the case
Old 06-28-2012, 11:09 PM   #6
ssewall
You'll want one from a junkyard. The aftermarket TPS are known to be flaky.
Old 06-29-2012, 04:02 AM   #7
td1238
Mine isn't flaky after a year, and it has a lifetime warranty from O'Reilly Auto.
However, O'Reilly has the part numbers for the different years mixed up in their computer, so make sure that the part number you get matches the original.
Old 06-29-2012, 06:08 AM   #8
Did you ever replace the original round nosed plastic coolant sensor with a flat nosed brass one?
Old 06-29-2012, 09:09 AM   #9
mansaturn
mansaturn is on a distinguished road
i hate being a broken record, but the top 2 causes of idle irregularities i've seen are 1) egr valve (clean it or replace it) and 2) intake manifold gasket, especially on single cams. spray carb cleaner around the intake gasket (back of motor) while the car is running, and if idle changes or car stalls while you're spraying, you've found the leak and the cause of your idle problem. TPS is almost never the cause in my experience. let us know how you solve it so we can all learn.
mansaturn is offline   Reply With Quote
2000 Saturn SL1 High Idle mfoster670 S-Series Tech 5 12-16-2013 10:18 PM
High idle on 2000 saturn Sl1 5 manual 1tallguy S-Series Tech 13 10-13-2011 03:31 PM
2000 Saturn L high idle Maxine L-Series Tech 1 02-27-2010 10:55 PM
2000 SL1 high idle amory S-Series General 3 03-06-2006 09:35 AM
high idle on sl 2000 vitali-k S-Series Tech 16 08-02-2005 11:03 PM
