Old 05-01-2020, 10:26 AM   #241
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Default Re: 98 SC2 project. Drive for now, maybe rebuild later.
Was there a layer of foam under the dash when you took it off? That looks like a piece of the foam insulation thatís supposed to be under there. Previous owner may have destroyed that as well and thatís all thatís left.
97 SL2, auto, 123K miles
Old 05-01-2020, 11:00 AM   #242
Yep, the foam is fine. I think I'm going to hand wash it in a bucket of soapy water. One of the prior owners was a smoker and I'm slowly getting the smell out.
Old 05-01-2020, 05:56 PM   #243
I think 96-99 should work. 95 was an odd transition year. They had an endcap on top.
Old 05-02-2020, 09:42 AM   #244
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
After washing, soak the foam in a bucket of water with 1 or 2 cups of baking soda overnight. Rinse, squeeze out the water and let dry before reinstalling the silly thing. I did this a couple years ago.
Next time I take out the dash cover I will replace the foam thingie, just cause I can.
Saturn 1998 - SL2 automatic
Singer Serger 1985 - 14U64A & 14U34B
Old 05-03-2020, 06:06 PM   #245
I think I will replace the foam. I have some handy.
Rather than go to LKQ I fixed my dash mount tabs. First I marked them.
Then I dremeled and sanded them off.
Riveted on:
A wrap of good duct tape around the tab and then the clip jams on:
Rivets
And the second one.
Old 05-04-2020, 01:47 PM   #246
I approve of using duct tape in your repairs
Clever solution!
Old 05-05-2020, 11:01 PM   #247
New foam marked up. I bought a sheet of this foam to make a new air filter for my 1981 Suzuki GN400.
Glued together and put in place:
Crap. Broke another tab. Fixed.
Rivets are visible but the repair is strong.
Old 05-13-2020, 01:12 AM   #248
I got my headliner fabric finally.
These busted tabs are getting to be a thing.
I busted my center brake light. I need an LKQ run.
Overall it came out pretty good.
Old 05-13-2020, 12:35 PM   #249
Nice work on the headliner!
Mine had a few minor wrinkles but they are covered by the passenger sunshade, so normally out of sight Plus a few areas where my sunroof is could use a little work. Part of why I have a love/hate relationship with the sunroof.
your LKQ comment reminds me, I need to make a run. I always forget that I was going to grab a flasher unit for the brake light (the kind that makes it flash 3x quickly before coming on). Figure it's cheap insurance against being rear ended.
Old 05-13-2020, 01:31 PM   #250
Thanks! It is definitely not perfect. Perfect is the enemy of good enough. Hopefully the smoke smell is reduced.
Old 05-13-2020, 03:28 PM   #251
Oh yeah, totally forgot - doing the headliner got rid of the last of that stubborn cigarette smell. I had already Febreezed everything but still had that noticeable whiff of smoke.
I never did clean the sunshades, rear tray, or seat belts other than Febreeze, wiping down, etc., but the replacing the headliner and cleaning the carpet was enough to get the smell out.
There was a decent amount of cigarettes stashed between the driver seat and center console. I had cleaned everything under the seat already, when when I removed the driver seat, these fell out
Over 20 cigarettes and butts
Old 05-16-2020, 02:44 PM   #252
That is awesomely nasty.
Went to LKQ yesterday to get a new 3rd brake light thing. I didn't realize the sedans have a different part. Since I struck out I'm fixing my broken one. I made a piece of sheetmetal to glue on.
The 5 minute epoxy is drying now.
Old 05-16-2020, 05:43 PM   #253
454cid
One of these days, I'm expecting to open this thread and find that you're using some sort of glue or resin to reattach you main bearing caps
2000 SL2 Automatic 200,XXX miles.
1999 Chevy K3500
Old 05-16-2020, 07:34 PM   #254
I can recall a motorcycle magazine article where they were testing a new loctite product - Form-a-Thread. They wanted to try it on conrod bolts.
Old 05-18-2020, 01:24 AM   #255
Came out good. Unfortunately all 3 bulbs are burned out.
Old 10-28-2020, 05:23 PM   #256
The DC resistance of the coil, 85 & 86 must be high enough that the current draw at 14.2vDC is less than 5mA or you will fry the car horn buttons and possibly the clock spring. It will work for a while before it all fails if the current is excessive. The diodes are a must have or the field collapse will burn holes in them.
Measure the coil resistance with a decent ohmmeter and use that resistance value to calculate the current.
Rich, if you are monitoring this from beyond, I just wanted to say you are right. My horn has died again.
Old 10-12-2021, 09:59 PM   #257
Before I stopped driving the SC2, I found a hitch at the junkyard. I cleaned it up and painted it.
I'll be using this to tow my sailboats, like the one you can almost see in the picture.
This is why I posted this thread:
http://www.saturnfans.com/forums/sho...d.php?t=269441
Old 10-23-2021, 09:39 PM   #258
I put my junkyard hitch on today.
Still need to redo the muffler hanger and do the wiring.
Old 10-24-2021, 09:32 PM   #259
I finished up my hitch installation including wiring.
The car has been very jerky at partial throttle, once it warmed up. It drove a lot smoother with the EGR valve connector unplugged. I bought a new Standard EGR and installed it. Very smooth now and my P0405 code is gone.
Old 10-26-2021, 04:18 PM   #260
I remember seeing a richpin vid about getting the flasher unit from any GM car and putting it into the Saturn. It's the circuit thingie that when you hit the brakes, flashes three times quickly before staying on. I keep forgetting about it on the rare occasion that I hit a JY (it has been years since I went to one) but is on my to do list
Summer Project:1.9 Engine Rebuild 1bignordic S-Series General 5 03-17-2014 02:29 PM
Rebuild VS Drive it as is VS sell it off OldSkewlSW1 S-Series General 11 03-09-2009 05:27 PM
Updated rebuild project hAnNibAl_H S-Series Mods 8 06-18-2007 12:17 AM
Current Project Towing New Project popp Vue Red Line 6 04-11-2006 12:55 AM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
