Old 12-28-2019, 11:59 AM   #401
Default Re: 99 SL2 rebuild thread
This post is just to link in my other thread on pressing the hub.
http://www.saturnfans.com/forums/sho...d.php?t=264433
Old 12-29-2019, 11:45 PM   #402
All back together and we went for a rainy test drive. The new clutch is awesome. The wheel bearings are quiet. Initially the idle was very high, like 2000. After it warmed up, 1700. We did a power cycle, no change. Revved it up by jamming on the pedal hard then it was good. Maybe TPS on its way out? Or a relearn from having the battery out for a week plus? One issue that remains is we are getting a pop from the right side under hard acceleration. Not sure if it is a shock mount or swaybar issue. Also the alignment is screwed up but I'm going to make an appointment to get that fixed.
Old 12-30-2019, 09:30 AM   #403
trottida
trottida's Avatar
Could the hard pop be a bad dogbone mount moving with the torque of the engine under acceleration? The other thing it could be is the top mount is loose. I had that happen once; the 3 studs attaching it to the timing cover loosened off allowing the mount to shift and clunk when releasing the clutch.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 12-30-2019, 10:36 AM   #404
chris's sc1
chris's sc1 is on a distinguished road
Ok. I see what your talking about now. I guess I havent done very many hubs. Usually I just buy it already together
chris's sc1 is offline   Reply With Quote
Old 12-30-2019, 11:55 AM   #405
Very possibly. Last night I ordered a set of pro-thane dogbone inserts. We will check the top mount. Thanks for the ideas.
Old 12-30-2019, 02:16 PM   #406
Top mount is tight. I have cheap dogbones on the '99 currently. Hope that is it.
Old 03-16-2020, 11:29 PM   #407
We took trottida's excellent advice and added 90 degree zerk fittings to our Mevotech control arms.
Also took Sid's excellent advice and loosened, re-torqued the control arm pivots. Popping seems much better. Got one pop backing up and turning but otherwise seems quiet. This was right after we put it back together.
http://www.saturnfans.com/forums/sho...d.php?t=266393
Old 03-17-2020, 08:10 PM   #408
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Hey Waiex191 I was trying to see where Trottida mentioned the zerk fittings and can't find the post. Can you explain how you did that? I had previously installed new bushings on my LCAs and have a popping sound on the drivers side, so I have bought new Dorman LCAs. Thanks!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2007 Subaru Forester LL Bean Edition
Previous:
2008 Honda Accord EX-L 2.4
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 03-18-2020, 12:07 AM   #409
Check out this thread for the 90 degree zerk idea:
http://www.saturnfans.com/forums/sho...d.php?t=266106
This is easy. Unscrew the old straight zerks, screw in the new 90 degree ones.
We had popping too. Then I read this thread, including Sid's linked thread.
We loosened up the control arm to cradle bolt, jacked up the control arm to the nominal position, and re-torqued it. No more popping. Try this before you swap them.
Old 09-05-2020, 07:10 PM   #410
The new alternator we installed back in 2017 has failed. I don't recommend this brand. It made it 20,000 miles. We are putting the original back in for now and will buy a DB Electric.
Old 10-12-2021, 09:57 PM   #411
Shift cable keeper broke. Fortunately my kid was just leaving for college and happened at the end of our street.
Bought one of these. It comes next week.
https://www.ebay.com/itm/124833995949
Old 10-20-2021, 10:33 PM   #412
The eBay part worked good. Car is on the road again.
01 SC2 Rebuild Thread Saturninin S-Series General 3 10-04-2015 08:11 AM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 08:00 PM
My Rebuild Thread Part II jswingchun S-Series Tech 21 04-23-2009 09:55 AM
My Rebuild Thread jswingchun S-Series Tech 40 02-12-2009 12:52 PM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
