Old 04-07-2017, 02:00 PM   #1
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
Default Dreaded Emergency Flasher button failure
I was driving on I5 in Del Mar and an 18 wheeler flips up this huge hunk of metal from his lane and it lands right in front of me. I slammed on the brakes and tried to avoid it. NOPE. Drove right over it and it got stuck under the Vue. I am still rolling but this metal is scraping the crap out of the road and screeching loud. I nailed the emergency flasher button and sure enough, it disappears into the dash, without turning on. I put on my right turn signal and scrape my way to the right curb. Turns out to be a car hood, bent over on itself. I managed to pry it free and dragged it out. Caltrans truck pulls up and thanks me for removing the debris from the highway. Quite a few folks managed to run it over as it turns out. No damage to the Vue.
The replacement bracket for the switch is no longer available from GM. I used about a quarter of a package of Permatex Plastic Welder to attach the switch back into the dash. It is very strong now. What a weak and pathetic attachment for a critical part of a vehicle. Should be a recall.
If you need to turn on the flashers, remember to do it "gently".
burlyvue2 is offline   Reply With Quote
Old 04-07-2017, 10:24 PM   #2
Mr Toad
Mr Toad has a spectacular aura aboutMr Toad has a spectacular aura about
Mr Toad's Avatar
Default Re: Dreaded Emergency Flasher button failure
I agree! I got curious one day and pushed the button. To my surprise it dropped into the dash. I did the same as you with JB Weld. It is better than factory now.
2005 Saturn Vue
Front Wheel Drive
3.5L V6 Engine
5AT Automatic Transmission
180,000+ miles
Mr Toad is offline   Reply With Quote
Old 04-08-2017, 06:57 AM   #3
waiter21
2003 VUE 2.2L
I used JB Weld to fix mine last year...
Old 04-08-2017, 10:27 AM   #4
Star Ranger
Star Ranger is on a distinguished road
Did you open up the dash to get the button out? When I got my Vue used, the button was already pushed in and I haven't made the effort to pull it out yet.
Star Ranger is offline   Reply With Quote
Old 04-08-2017, 10:55 AM   #5
burlyvue2
2004 VUE 3.5L
Not sure what year your Vue is but here is a pretty good visual on how to get to it. There is only 4 screws holding mine on and pressure held clips.
https://www.youtube.com/watch?v=E1f_aegHUVk&t=3s
Good luck!
Old 04-13-2017, 04:19 PM   #6
Robert1969
Robert1969 is on a distinguished road
2004 VUE 3.5L
Worked for me also. I took out the mechanism, used crazy glue on the parts that broke and it's just fine for me.
When I bought the vehicle the used car dealer told me he sees that broken "on all of 'em"
Robert
Robert1969 is offline   Reply With Quote
Turn Indicators Burn Fuse and Emergency flasher Buzzes Demsyter S-Series Tech 14 04-08-2013 02:57 PM
Need help with flasher/turn signal failure kssherod L-Series Tech 6 12-03-2007 09:01 AM
Dreaded BCM Failure rayw1199 L-Series Tech 4 09-14-2007 12:32 PM
four way flasher button bob3434dog Vue General 2 03-27-2007 12:30 AM
4 way flasher button kayaksonvue Vue General 2 09-03-2004 02:51 AM
