Old 09-23-2021, 04:20 AM   #1
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
Default Rear lug stud removal
94SC1 with rear disc brakes - snapped off rear lug stud last night.
Do I just knock it through the other side like most other old cars? Thanks.
Baron5867 is offline   Reply With Quote
Old 09-23-2021, 09:47 AM   #2
Default Re: Rear lug stud removal
Yes.
It'll be a bit tricky getting the new one in, there's only 1 area behind the hub that's long enough for the full stud to fit through.
Old 09-23-2021, 11:05 AM   #3
Baron5867
1994 SC1
Originally Posted by fetchitfido View Post
Yes.
OK. I don't think I have ever replaced a lug stud on a rear wheel (e-brake) with disc brakes before.
And I guess I'll find out about installation when I get there.
Car has been sitting awhile (see my classified), but I was surprised that when I went to pull the LR wheel off to check a brake leak, the lug nuts gave me trouble all the way off, all four of them. I had better pull all the wheels off, to see if I am going to be needing any more new lug studs.
Old 09-26-2021, 02:33 AM   #4
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
Personally, I'm a little hesitant of beating on the end of that stud. After all, the hub it's installed in, is riding on the rear bearing. So beating on it, basically, is beating on the bearing. And you can't expect it to last too long after that.
You'd be better served to find some way to press it out. Or put some support behind the hub next to the stud you're removing.
And of course, you pull it back into place using a standard lug nut BACKWARDS.
You can't use the factory Saturn lug nuts, because you can't get a socket on the nut if you put it on the stud backwards. And you shouldn't used the beveled end of the nut to drive against the hub face. So you'll have to purchase a standard lug nut when you buy the replacement stud.
Preston
PrestonIII is offline   Reply With Quote
wheel stud removal harlan41 Ion Tech 3 08-07-2013 10:24 PM
Motor mount stud removal question FredM S-Series Tech 14 05-09-2012 12:20 AM
Wheel stud removal (ASAP) saturncrzy S-Series Tech 2 01-28-2009 11:13 PM
pound out rear wheel stud? eljefino Miscellaneous Tech 5 03-22-2004 05:22 AM
How do I replace rear wheel stud? srponies S-Series Tech 2 01-18-2003 04:51 PM
