Old 08-24-2021, 03:23 PM   #1
clockrepairman
clockrepairman is a jewel in the roughclockrepairman is a jewel in the roughclockrepairman is a jewel in the rough
Dazed po420 po430 code
Hello, just wanted to post that I had the code po420 pop up on my Saturn Aura XE 96,000 miles. This car has never wanted for an oil change, I have just got lazy and have paid to have the oil changes done. I always assumed that the tech would try to sell parts and check the air filter and things like that. I guess not. I used my code reader and pulled up the graph showing the before and after ratings on all 4 O2 sensors, the lower sensor on bank 1 was all over the place. Fortunately, I did some more research and found one website that said to check the air filter. I pulled it out and it was very plugged. I took it out threw it away and ordered a fresh one, I started up the car and let it warm up and watched the graphs of all 4 O2 sensors after they were warmed up bank 1 was erratic for a short time, and it just slowly looked almost identical to bank 2. The problem is solved. Lesson learned, start with the easiest, cheapest possible cause and start there. I am so glad I didn't purchase a pre cat for it. I wonder how often this is misdiagnosed?
clockrepairman is offline   Reply With Quote
Old 08-26-2021, 07:37 PM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: po420 po430 code
Good info, thanks
Tags
catalytic converter
1997 SC2 code PO420 ( i know, lots already here) LAD420 S-Series Tech 2 09-01-2016 07:49 PM
po420 code ...is it the cat, or could it also be the rear o2 that is bad & cat is ok? fixityourselfer S-Series Tech 1 12-08-2010 11:56 AM
Need help with engine light code PO430 tripplegs Aura General 10 12-06-2009 06:12 PM
Code #PO420 Gravity Dancer S-Series General 3 08-19-2007 02:33 PM
Engine code PO420 Sam96SL2 Miscellaneous Tech 13 08-13-2003 02:06 PM
