Old 09-11-2014, 07:39 PM   #1
Roy Lee
Roy Lee has a spectacular aura aboutRoy Lee has a spectacular aura about
Default '08 Aura won't start
Hello everyone, new to forums, been driving Saturns for years. My family owns 3 sl2's, an Ion, and an Aura.
The '08 Aura won't crank, battery voltage is good. No security light, tried both keys just in case. When I turn the key to on, fuel pump does not run either. Relay 32 (run/crank, ignition) is getting 12v, starter relay 31 is receiving no voltage to it's coil. There is voltage at the contact terminals of relay 31, and if I jump them, the engine will crank but not start. So, it seems like key on, dash lights okay, no fuel pump. Key in start, not sending signal to starter relay. I thought about the neutral safety switch, but that shouldn't keep the fuel pump from running, correct? I can't find a wiring diagram anywhere, so I am here asking for help from anyone who would be so kind to do so.
Thanks
Roy Lee is offline   Reply With Quote
Old 09-11-2014, 08:36 PM   #2
Default Re: '08 Aura won't start
Which model, engine? Checked for blown fuses?
Old 09-11-2014, 09:02 PM   #3
Roy Lee
According to the VIN, the engine is the 2.4 DOHC L4 VVT
I checked the fuses under the hood at the relay center, and in the passenger compartment, they all tested good.
Thanks
Old 09-12-2014, 12:04 AM   #4
From your brief descriptions, this seems to be a Pass-Key III security issue as the factory security system disables starting and fuel. Are there any aftermarket electronics?
Old 09-12-2014, 01:19 AM   #5
Roy Lee
The car is completely stock, no modifications. I'm not familiar with passkey III. I didn't see a security light as I am used to with the older systems. Is there any way i can get around this?
Thanks
Old 09-12-2014, 02:31 AM   #6
If you have the owner's manual, read it. Pass-Key III is GM/Saturn's theft deterrent system - car immobilizer using the rfid/chip in the ignition key to enable/disable the EFI and starting system. Your keys are coded and read by the theft deterrent module in the ignition switch assembly to allow engine operation. No manual? http://www.saturn.com/owners/owner_r...s/manuals.html
There is a security indicator to tell you when its operating, in standby mode or disabled when it fails it own self tests to prevent being locked out from starting and driving your car. This presumes the battery has sufficient power for vehicle electronics and your ignition keys are original rfid transponder keys and not plain copies. There is no real bypass method to GM's security system as its embedded into the electronics and spread out to several modules including the transponder module in the ignition switch assembly. If you cannot start the engine with a good battery, you may have to tow the car to GM for proper troubleshooting and repairs.
Old 09-12-2014, 05:53 AM   #7
Roy Lee
Thanks for your help fdryer. I'll look into this, and post back when it's resolved
Old 09-12-2014, 09:27 AM   #8
golftango
golftango will become famous soon enough
golftango's Avatar
This. I'm suspecting the battery is on its way out. OE battery?
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
golftango is offline   Reply With Quote
Old 09-12-2014, 10:29 AM   #9
Roy Lee
Battery has been replaced, good connections and voltage. Tried jump starting for the heck of it. When I jumpered the contacts on the starter relay, it cranked at a normal speed, so the battery does seem okay
Old 09-12-2014, 02:18 PM   #10
There's more to this than you may have imagined......
File Type: pdf immobilizer-description-and-operation.pdf (27.3 KB, 32 views)
File Type: pdf pass-key-iii-electronic-immobilizer-operation.pdf (23.2 KB, 16 views)
Old 09-12-2014, 03:53 PM   #11
greenman
2009 AURA XE
i'd start by checking for dtc's. note most security system codes are body codes that a basic reader can't see.
Old 09-21-2014, 02:03 PM   #12
Roy Lee
Just an update for all who were so kind to help.
Had the car towed to a dealer, and they said the ECM was bad. Guess I have to take their word
Old 09-21-2014, 02:57 PM   #13
Ouch!? That's not saying much for ecm longevity.............
Old 09-21-2014, 05:42 PM   #14
billysvue
And before they soak you with a huge bill they will guarantee it for how long?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 09-22-2014, 12:26 AM   #15
greenman
2009 AURA XE
8 yr/80,000 mi warranty on original ecm.
Old 09-22-2014, 05:50 AM   #16
Roy Lee
There really is such a warranty on the ECM?
Old 09-22-2014, 03:14 PM   #17
greenman
2009 AURA XE
yes. it's mandated by the federal emissions warranty coverage. covers all cars since '95.
Old 09-29-2014, 10:14 AM   #18
Roy Lee
I just wanted to thank everyone for their help, especially greenman who made me aware of the warranty on the ECM. The dealer tried charging for a new ECM, but I had printed out a copy of the 8 yr, 80,000 mile coverage. He said he never heard of that warranty before, but nonetheless, deducted it from our bill. I never had faith in car dealers, and this mans poor ability to lie has reinforced my thinking.
Thanks again to all.
Old 09-29-2014, 11:01 PM   #19
greenman
2009 AURA XE
I know i should be shocked by such blatant lying but it just doesn't surprise me much anymore.
Old 10-09-2021, 07:41 PM   #20
nailheadjim
nailheadjim is on a distinguished road
Thanks
Hey Roy. I know how frustrating this problem is having just gone through the same problem. I had read about another Saturn Aura owner found that the ground wire on the drivers side engine block has a 5 wire ground that controls the ground for the neutral safety switch. I hooked up a scanner that tells you what each module has going on with it. When my car is is in park the ecm says it was in gear. Sure enough I wriggled that ground cable and watched the scanner screen jump back and forth from in gear to park neutral. when I got the wire to say it was in park neutral it would start. Clipped the old terminal off and replaced with a new one and it starts right up every time. Hope this helps.
nailheadjim is offline   Reply With Quote
07 aura wont start moss122 Aura General 19 09-16-2013 11:34 PM
2007 Aura XE won't start jthigpen Aura General 4 06-11-2013 06:28 PM
start my aura retrofit belizeanlow Aura General 30 08-28-2010 08:55 PM
Remote Start 07 Aura bradt123 Aura General 1 02-26-2007 01:51 PM
The Aura sales has to start somewhere DeMAN Aura General 25 10-14-2006 01:52 PM
