Old 10-25-2011, 08:46 PM   #1
d_rock
d_rock is on a distinguished road
d_rock's Avatar
2005 ION-3 Quad Coupe
Default Car starts, but passlock light is on and fuel gauge shows empty
I have a kind of weird passlock problem that I haven't found an answer to by searching...
My car DOES start, but the passlock light is on and my fuel gauge shows empty even though I know it has about 3/4 tank full.
Also the display says "TRAC OFF" and I noticed my trac button can't turn it back on.
I was able to drive my car a bit too, so clearly the fuel pump isn't deactivated like it should be.
What problem can this be indicative of? Doesn't seem like the usual ignition/starting problems.
"Pessimists see the glass as half empty, optimists see the glass as half full. Engineers see that the glass is twice as big as it needs to be."
2005 Saturn Ion-3 Quad Coupe, Automatic
d_rock is offline   Reply With Quote
Old 10-25-2011, 09:17 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Car starts, but passlock light is on and fuel gauge shows empty
sounds like it's not a passlock problem. probably an IP or BCM problem.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 10-26-2011, 05:18 AM   #3
d_rock
d_rock's Avatar
Thanks, 2006
Shouldn't that throw a code of some kind? I don't have a check engine light on.
The problem is now intermittent, I started the car several hours later and it no longer displayed the symptoms from my opening post.
Old 10-26-2011, 05:49 AM   #4
2006 ion2
2007 ION-2 Sedan
No, neither one would throw a code
Old 10-26-2011, 08:29 AM   #5
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
Wondering if the passlock and disabled Fuel Gauge are directly associated. (Security feature?) Then the TRAC OFF maybe a partially applied parking brake?
So if the passlock issue is fixed (and the brake isn't set)... problem over?
lgodave is offline   Reply With Quote
Old 10-26-2011, 12:38 PM   #6
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Disconnect your battery for 10 minutes, reconnect and try again. Just be sure your radio is not password protected.
chilipepper1327 is offline   Reply With Quote
fuel guage shows empty portholediver S-Series General 8 11-01-2010 11:11 PM
No start, fuel gauge says empty. getz_999 S-Series Tech 7 08-06-2010 02:27 AM
92 SC2 Fuel gauge - never full, never empty Wizard Prang S-Series Tech 5 04-03-2008 09:55 AM
Fuel Gauge fails / stops working / goes empty while driving?? [Atari] S-Series Tech 3 07-26-2007 12:20 PM
Fuel Gauge on empty, no start Collegeboy S-Series Tech 2 09-18-2006 04:19 PM
