Old 02-08-2011, 05:05 PM   #1
ameyer
ameyer is on a distinguished road
Default 2008 Saturn Aura Plug Wires/Plugs Replacement
Hello:
First time for me. Can anyone explain in DETAIL how to replace the spark plugs & wires in my 2008 Saturn Aura 3.5 engine? Can a backyard mechanic like myself do this? Dealer wants $500.00 for this service.
Thanks so much.
Ang
ameyer is offline   Reply With Quote
Old 02-08-2011, 05:40 PM   #2
greenman
2009 AURA XE
Default Re: 2008 Saturn Aura Plug Wires/Plugs Replacement
might seem expensive but it's worth every penny...
http://www.helminc.com/helm/product2...8SM&itemtype=N
Old 02-09-2011, 03:44 AM   #3
greenman
2009 AURA XE
$500 is outrageous for R&R of plugs & wires.
Old 02-10-2011, 10:32 PM   #4
carlover
carlover is on a distinguished road
2008 AURA XR
Do you really need to change the plugs and wires? How many miles are on the car? How does it run?
Drive like you mean it, keep the rubber side down.
carlover is offline   Reply With Quote
Old 02-13-2011, 11:29 PM   #5
Nettel
Nettel is on a distinguished road
2007 AURA XR
What? $500. Plus I just had it done on another car of mine with 114kmiles. The wires should last to 100k. Unless the manual has that as part of a scheduled maint. pending on how many miles you have
Nettel is offline   Reply With Quote
Old 02-28-2011, 04:43 PM   #6
Tom1222
Tom1222 is on a distinguished road
On a lot of modern sideway mounted engines you have to take the manifold off in order to get to the spark plugs. This is very labor intensive and most of that 500 bucks they want to charge you is labor. Sparkplugs these days are designed to last 100k miles or more. So unless you have some missing or other engine issues I would wait until it really needs spark plugs. Also only a handful of modern cars still use Sparkplug wires. Most of the cars now have coil on plug systems which are a lot more efficient than the old sparkplug wires and usually outlast the car unless there is an issue with one of the coils.
I am picking up my Aura tonight so I can't tell for sure but I will take a look underneath that massive plastic cover and see how difficult it is to get to the spark plugs and the overall ignition system.
Tom1222 is offline   Reply With Quote
Old 02-28-2011, 05:00 PM   #7
greenman
2009 AURA XE
for the '08 3.5L (sans diagrams):
Spark Plug Wire Replacement
Removal Procedure
Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
Remove the intake manifold cover. Refer to Intake Manifold Cover Replacement .
Disconnect the left side spark plug wires from the spark plugs.
Disconnect the left side spark plug wires from the ignition coil.
Remove the spark plug wire clips from the manifold absolute pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
Remove the spark plug wire assembly.
If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
Disconnect the right side spark plug wires from the spark plugs.
Disconnect the right side spark plugs from the ignition coils.
If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
Installation Procedure
Install the spark plug wire assembly.
Connect the right side spark plugs to the ignition coils.
Connect the right side spark plug wires to the spark plugs.
If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
Connect the left side spark plug wires to the spark plugs.
Connect the left side spark plug wires to the ignition coil.
Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
_________________________________________________
Removal Procedure
Remove the engine oil fill cap.
Pull up on the cover in order to disengage the cover from the studs.
Old 02-28-2011, 06:55 PM   #8
Low Saturn
Low Saturn's Avatar
2007 AURA XR
You got that right. Worth every cent. The first time you use them to complete a repair you otherwise would have to take the car to the dealer for, you made back all the money you spent on them.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 09-06-2021, 08:46 PM   #9
GotAnswerz
GotAnswerz is on a distinguished road
2008 AURA XE
Originally Posted by ameyer View Post
Hello:
Thanks so much.
Ang
That is the exact car I have, 2008 Saturn Aura XE. To replace the spark plugs I need only to remove the spark plug wires from the distributor and I have plenty of access.
GotAnswerz is offline   Reply With Quote
Old 09-07-2021, 02:55 PM   #10
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Pontiac G6 is same as Aura...hope this helps.
https://www.youtube.com/watch?v=lPt3SeSt1S8
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 08:29 AM
Spark Plug wires and plugs soccer69er Classifieds 1 04-01-2004 09:52 PM
Plug wires, coil packs, plugs..followup sc2_94 S-Series Tech 10 06-22-2002 12:36 PM
plugs and wires replacement Jeff P S-Series Tech 9 01-18-2002 12:46 AM
