Old 10-05-2008, 08:48 PM   #1
grinthenbearit
grinthenbearit is on a distinguished road
grinthenbearit's Avatar
Wrench tips on fixing a sl2 2000 saturn, with a coolant leak, near the right front tire
I went to a radiator repair shop, then they just ripped me off.
I still have he leak by the front right tire.
Any tips on plugging the leak will be greatly appreciated!
GOD BLESS AMERICA
grinthenbearit is offline   Reply With Quote
Old 10-05-2008, 09:19 PM   #2
wishihadacamaro
wishihadacamaro is on a distinguished road
Default Re: tips on fixing a sl2 2000 saturn, with a coolant leak, near the right front tire
Do you mean the puddle of coolant is near the right front tire? You might have a leak in the reservoir or a loose/cracked hose if that is the case.
wishihadacamaro is offline   Reply With Quote
Old 10-05-2008, 09:28 PM   #3
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
Check the water pump.
1995sl1sohc is offline   Reply With Quote
Old 10-05-2008, 09:54 PM   #4
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
He's got it +1
johnny95sl2 is offline   Reply With Quote
Old 10-06-2008, 12:42 AM   #5
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
I'll bump it to +2 on the water pump. With the engine running, you should be able to see coolant dripping from under the pump.
I've done a couple of these on my 99 S-cars and this link has been helpful:
http://www.saturnfans.com/forums/showthread.php?t=24144
I've gotten my pumps at AutoZone and they've done fine. I'd also recommend that you consider replacing your serpentine belt while you have everything torn apart anyway. I got that part from the dealer.
The last time I swapped a pump, I used the air compressor and impact ratchet to get at some of the bolts on the pulley and the pump housing. It's definitely a tight squeeze in some of those spots. Have patience!
jambra1 is offline   Reply With Quote
Old 10-06-2008, 04:28 PM   #6
grinthenbearit
Wrench Re: tips on fixing a sl2 2000 saturn, with a coolant leak, near the right front tire
the puddle starts dripping, within seconds of fluid being hand poured into the overflow resev., before the engine starts.
tips on what tools i need to fix this problem please
thanks in advance
Old 10-06-2008, 04:36 PM   #7
You can't see the coolant/water pouring out the shaft on the water pump? May indicate it's another part of the cooling system...but it should be just as obvious as water pouring out the shaft on the water pump or out the gasket where the pump mates to the block.
I believe most of the bolts are 10mm, the tensioner is 14mm, lug nuts are 19mm (might be easier to go through the wheel well), and you'll need something to hold the water pump pulley in place so you can get the 3 bolts out to get to the other 6-8 that hold the pump in.
Old 10-06-2008, 05:31 PM   #8
grinthenbearit
i definitely can't see the leak source
thanks for any help, wheel well sounds right for the job
Old 10-06-2008, 05:42 PM   #9
moelarrycurly4
moelarrycurly4 is on a distinguished road
1997 SL1
...... and you'll need something to hold the water pump pulley in place so you can get the 3 bolts out to get to the other 6-8 that hold the pump in.
Leave the belt on until you get the bolts loose
moelarrycurly4 is offline   Reply With Quote
Old 10-07-2008, 06:22 AM   #10
BarnOwl
BarnOwl's Avatar
First off that's not an overflow. It's a pressurized part of the cooling system. You probably have a crack in the reservoir. Pull it so you can get a good look at it then head to the U-Pull-It for another one.
Am I really boned? 2000 SL2 coolant head leak pic. RarestRX S-Series Tech 15 10-30-2009 09:02 AM
Coolant leak on drivers side of 2000 SL2 sdgengineer S-Series Tech 10 12-16-2008 12:41 PM
2000 LS2 Another coolant leak between5and7 L-Series General 2 08-09-2006 04:52 PM
2000 Ls2 Coolant Leak Tony L-Series Tech 32 10-24-2002 01:28 PM
Need tips on a 2000 SL2 Front Brake job 2000sl2blue S-Series Tech 4 01-25-2002 12:57 PM
