Old 10-15-2021, 05:57 PM   #1
Racemysaturn4me
Racemysaturn4me is on a distinguished road
1997 SC2
Default 1997 Saturn SC2 Knock Sensor Issues
Hello everyone. I've been having an issue with the knock sensor. I've had it replaced twice in the last few weeks and still getting the check engine light and code showing knock sensor issue. Anybody know what could be wrong? All the new sensors can't be bad. Could it be the harness wires? Any help is appreciated!
Racemysaturn4me is offline   Reply With Quote
Old 10-15-2021, 06:27 PM   #2
onlinebiker
Default Re: 1997 Saturn SC2 Knock Sensor Issues
Any symptoms to report or just codes?
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 10-16-2021, 01:54 PM   #3
Racemysaturn4me
1997 SC2
So far just codes.
Old 10-16-2021, 05:41 PM   #4
onlinebiker
Originally Posted by Racemysaturn4me View Post
So far just codes.
I went through this last year... It turned out to be - believe it or not - a broken spark plug ceramic.......
As I understand it - the knock sensor works sonically. Check for stuff rattling near the engine. ( body rattles shud be isolated by the engine mounts)
Good luck - it can be a bugger to find....
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 10-16-2021, 06:39 PM   #5
The 2 knock sensor codes I can find, since OP can't take a hint and tell us what code(s) they have:
P0326 is too much noise (things like onlinebiker mentioned)
P0327 is generally wiring issues (loose connection somewhere in the wiring including sensor loose on block) but, worst case, indicates a bad PCM.
knock sensor, saturn, sc2 1997
1998 Saturn sc1 knock sensor Mysaturnbeater S-Series General 2 03-19-2018 03:27 AM
1997 Saturn 4 Door DOHC Loud Engne Knock epeterson S-Series Tech 5 05-17-2013 01:34 PM
P0327 - Knock Sensor and other issues... Scholzpdx S-Series Tech 2 11-08-2012 11:05 AM
2003 Saturn Vue V6 AWD - knock sensor? skullzsalon Vue Tech 2 08-08-2011 02:52 AM
what solves excessive spark knock (besides knock sensor) geartooth94 Miscellaneous Tech 15 09-26-2004 09:36 PM
