Old 07-12-2010, 12:17 PM   #1
Taxbert
Taxbert is on a distinguished road
Default Air Vent Control Not Working
I have a 2008 Saturn Vue. The air flow vent control is not working. The A/C works and the blower motor is working. The air is coming out by the feet, the side vents and a little out the front vents. But when I turn the dial (i.e. defroster, front vent, etc.) nothing happens. How does the vent control knob control the vents? Is it vacuum or electrical? Any thoughts on what could be wrong?
Taxbert is offline   Reply With Quote
Old 07-12-2010, 03:30 PM   #2
leogag1
leogag1 is on a distinguished road
leogag1's Avatar
2009 VUE 3.6L
Default Re: Air Vent Control Not Working
It is electrical. If I were you, I'd check the cables and plugs. Maybe it's simply unplugged.
____________________________
Léo Gagné
Professional Engineer
Software Designer and Architect
leogag1 is offline   Reply With Quote
Old 07-12-2010, 03:56 PM   #3
smailmanstn
smailmanstn is on a distinguished road
I had a similar (if not the same) problem with my "08 XE, a little over a year ago. Under warranty, my local Saturn dealer replaced some switch or relay in the control panel.
As I recall, the A/C would only go through the floor vents, and the defrost position pushed through the front dash panel vents, as if the control switch were miswired. But i knew that wasn't the case, because the problem DEVELOPED: the controls worked correctly up to that point.
I had the impression that this was not an unknown problem. The dealership fixed it in a couple of hours (I belive a computer reset was involved). Mine has been working perfectly since. Hope this helps.
smailmanstn is offline   Reply With Quote
Old 08-18-2014, 01:11 AM   #4
Raptorstwo
Raptorstwo is on a distinguished road
Progress report.
Finally found time to work of the switch. It was much simple that I expected.
1. Remove BEZEL. Place fingers in the 2 air vents above the radio. Give it a good sharp SHORT pull.
Short because bezel is held in place by spirng clips:
2 on top, 3 on each side, 2 at bottom. Work your way down both sides releasing clips on each side.
Note Of Caution: I don't know what kind of plastic the bezel is made of but I suspect it may be brittle when cold. You may need to warm it up if the car is very cold.
This exposes the Radio and the Heater Controls. Each are held in place by one screw of each side.
Use nut driver or socket to remove radio. (Disconnect the wiring harness at the blue connector plug, not the wide narrow grey one.)
This exposed the heater/ac controls.
I did not have to remove the heater control unit. My problem was the plastic gears at the Flow Control Switch. I was able to just turn the horizontal gear by hand which got it back into its proper position.
Swith turns like new.
Hope this works for you. Please let me know if you got this message. Good luck.
Richard.
This works. I did what Richard posted. I want to tell everyone. I've been years without after spending $600 to mechanics who couldn't fix it. Thank you Richard.
Raptorstwo is offline   Reply With Quote
Old 08-21-2014, 10:23 PM   #5
brwct08
brwct08 is on a distinguished road
Well I just started having the same problem. AC is blowing at feet very strong and lightly up top. I can't change it. 2008 VUE XR. I tried removing the battery for rest and it did nothing. I read online that it could be the actuator under steering column. Any help?
brwct08 is offline   Reply With Quote
Old 09-06-2014, 09:00 AM   #6
russellgs1
russellgs1 is on a distinguished road
I just started having the similar problem as described above. AC is blowing onto the floor strong and lightly through the dash vents. I can't adjust it to any one location. 2008 VUE XE 4 Cyl. Does anyone think this tread and suggestions are relevant to this problem? Any help? Thanks in advance.
russellgs1 is offline   Reply With Quote
Old 10-06-2014, 09:48 PM   #7
tjhess74
tjhess74 is on a distinguished road
1996 SL1
this topic is my BIGGEST pet peeve with our vue. every single year about this time, our air system does this, or some strange variant thereof. in fact, we just got it back from the shop for this very thing.
four years straight now, the dealer does a reprogram and replaces the control head (the hvac dial knobs). it works great...until the following fall,.
ill take my bezel and radio out and take a gander at what you are talking about. id love for it to be so simple to shove in the dealers face. each year, i rub in the fact that they keep saying 'we finally got it this year'.
on a side note, our symptoms range from no mode control (defrost, vent, floor, etc), no temp control (ALL burning hot or all freezing cold), or both at the same time. the issues can cycle with the on/off cycle of the ignition.
the last time ours was stuck on full heat, we closed the vents, rolled down the windows on a 75 degree day while on the highway, and measured the surface temp of my dash in multiple spots with an ir temp gauge at 117 degrees!
tjhess74 is offline   Reply With Quote
Old 10-29-2015, 12:04 PM   #8
mbh47720
mbh47720 is on a distinguished road
try this from someone else on this board
and Save the trip to the dealer
Follow this procedure exactly:
Turn key on - eng not running
Calibrate the mode actuators by simultaneously pushing the A/C and RECIRC buttons on the HVAC control module 3 times each, within 2 seconds of initial push.
1. The A/C and RECIRC button LED's will flash while this calibration is taking place.
2. The calibration will take anywhere between 10 to 30 seconds depending on battery voltage.
3. The LEDs will quit flashing when the calibration is complete.
Cycle the ignition off then back on and verify proper operation
mbh47720 is offline   Reply With Quote
Old 11-07-2015, 05:06 PM   #9
mbh47720
this DID NOT work for me sorry
Old 11-30-2015, 10:34 AM   #10
carochio
carochio has a spectacular aura aboutcarochio has a spectacular aura about
Needs to be reprogrammed...
search for post# 2155261
It wont let me post the link at the moment.
carochio is offline   Reply With Quote
Old 11-02-2018, 10:03 AM   #11
Kartboarder22G
Kartboarder22G is on a distinguished road
I had no heat and no vent position control. Took it to a non dealer and he changed the motor acutator for the heat control and reset the limits on it. Now when everything is set to auto I get heat just out of the floor vents mainly. Also when St to manual max heat max blower I only got the car to about 80 degrees in the cabin and that was after a 22 Mile drive and 33 degrees out. What is going on I'm bringing the car back to him soon but he is recommending a heater core flush. That still doesn't fix the vent out the bottom when in automatic mode. Help? Probably should have went to a dealer.
Kartboarder22G is offline   Reply With Quote
Old 08-13-2019, 02:38 PM   #12
LKaan
LKaan is on a distinguished road
Hello, I have the same issue. 2008 Saturn Vue XR FWD.
I've pulled the actuator on the passenger side and found that it still moves in both directions when power is supplied. I used a voltage tester to find out if it's getting power from the wires in the harness, it would seem now power is being supplied any longer. I'm not sure what sends the power to the actuators, can't find any fuse that correlates. Could it possibly be one of the BCM fuses? My next option is to try to get the other actuator out for testing and try it on the passenger side. They are identical so they can interchange.
Any other suggestions would be greatly appreciated.
Also sorry for possibly hijacking the post, though it's the same vehicle and problem.
LKaan is offline   Reply With Quote
Old 09-19-2019, 12:30 PM   #13
He1
He1 is on a distinguished road
Raptorstwo
Thank you, I need to replace the three vents above the radio. Is there a vendor that I can purchase with out taking out a loan ? Also can you explain a bit more on the 'Short Pull' ?
He1 is offline   Reply With Quote
Old 07-02-2021, 02:36 PM   #14
tony2u
tony2u is on a distinguished road
My problem is: When I hard accelerate. The AC goes warm. Then when the car returns to cruising speed or stopped. The AC gets cold again. I think it is a vacuum line. But I cannot find any documentation that the vents on this car are controlled by
tony2u is offline   Reply With Quote
Old 10-14-2021, 03:05 PM   #15
spizwhit
spizwhit is on a distinguished road
2008 VUE 3.6L
Originally Posted by Raptorstwo View Post
Progress report.
Richard.
Note, these instructions are for < 2007 vues. >2008 Vues have 3 vents above the radio, and the dash comes out differently. HVAC control head is probably different too.
spizwhit is offline   Reply With Quote
Old 10-14-2021, 05:35 PM   #16
spizwhit
2008 VUE 3.6L
Wiring Diagrams in case they are useful for anyone. Automatic A/C for XR.
air flow, vent control
cruise control not working xraytec1 Ion General 17 01-27-2019 11:48 PM
Vent Control Knob Saturn#5 Astra General 14 04-30-2009 10:07 AM
Cruise Control not working gfreek1 S-Series Tech 7 06-29-2007 12:07 PM
vent control issues racegirlfor1 Ion General 1 04-10-2007 11:49 PM
Vent control cable problems cozwurth S-Series Tech 2 08-30-2006 12:45 PM
