Old 04-23-2020, 08:50 PM   #1
Coreykaq
Coreykaq is on a distinguished road
2008 AURA XE
Default Saturn aura won't move in gear
I've got a 08 saturn aura xe 3.5 I just replaced the 2-3 shift solenoid now it won't move in gear. It goes into park but every other gear feels like neutral. It just revs up but doesn't move. Any suggestions on what it could be? Also no check engine light.
Coreykaq is offline   Reply With Quote
Old 04-25-2020, 06:53 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: Saturn aura won't move in gear
What was the reason you changed the solenoid?
First thought is low fluid level since all gears are affected. Did you check the fluid level?
or
Plugged filter.
or
Broken shift linkage.
or
Bad torque converter.
Old 01-09-2021, 01:32 PM   #3
Enigma_G87
Enigma_G87 is on a distinguished road
i'm having the exact same problem with car (aura xe 3.5). did you solve the problem?
Enigma_G87 is offline   Reply With Quote
Old 02-10-2021, 04:16 AM   #4
nickson
nickson is on a distinguished road
Try checking your axles.
nickson is offline   Reply With Quote
Old 02-10-2021, 05:36 PM   #5
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Cracked oil feed tube?
https://www.youtube.com/watch?v=kE6cnIarrnQ
Old 10-12-2021, 02:19 AM   #6
TheTitanThanos
TheTitanThanos is on a distinguished road
2007 AURA XE
I had a similar issues a few years ago. I put it in park, then the next morning noticed it would slide freely between the other gears. If it helps, in my case it turned out to be a broken Shift Cable Bushing which I located between the engine and the battery. I ordered a replacement "Shift Cable Bushing kit" from bushingfix .com and that fixed it. Took 5 mins and no trouble at all to replace.
Good luck
2007 Saturn Aura XE
TheTitanThanos is offline   Reply With Quote
SL2 Won't Move in Any Gear Rabbitto S-Series Tech 17 11-23-2014 07:38 PM
02 sls runs but wont move in gear mleslie S-Series General 2 04-26-2011 09:46 PM
1996 Saturn SL 5sp won't move in gear pimpin88 S-Series Tech 8 06-30-2010 10:10 AM
Saturn Aura gear? wtxskater Aura General 5 10-08-2006 08:07 AM
'93 SW2 goes into gear but does not move gengel S-Series Tech 13 08-22-2006 06:29 AM
