Old 10-02-2021, 09:10 PM   #1
zakkx92
zakkx92 is on a distinguished road
Default Wire replacement for the Vapor Canister Vent Valve
Hi guys, I have a saturn ion 2007, have the code P0449. Upon checking the vapor canister vent valve, the cable chewed off ... So I ordered the HARNESS 19257603 but it is way too short. What is the original wire harness for this vent valve?
zakkx92 is offline   Reply With Quote
Old 10-03-2021, 10:13 AM   #2
zakkx92
Default Re: Wire replacement for the Vapor Canister Vent Valve
https://www.amazon.com/APDTY-Connect...CB3CGD9FJMK32D
Would this work on the Ion 07 ?
Old 10-03-2021, 11:57 AM   #3
It's not well known except to industry insiders but some vehicle wiring uses vegetable products in the insulation that attracts animals. This explains members finding their wiring chewed, leaving exposed or broken wires.
If you're familiar with soldering, can you just add extension wires and finish with shrink tubing for a weather resistant repair. If soldering wires isn't possible, butt connectors work with either larger shrink tubing or sealing with general purpose silicone seal. Refrain from using electrical tape as the adhesive softens summer and engine heat with tape unraveling after a year or so, leaving a sticky mess.
Old 10-03-2021, 11:00 PM   #4
zakkx92
Okay I will give that a go, thank you for the reply!
03 - 3.0 litre Saturn Vue needs canister vent valve.. burnt orange Vue General 5 09-05-2021 07:35 PM
2003 Saturn Ion 1, Vapor Canister Vent Valve fsc66 Ion General 2 07-12-2020 12:42 PM
When should the vapor canister vent solenoid be receiving power? clinteastwood S-Series Tech 2 04-30-2020 09:40 AM
Vapor Canister Purge Valve / Vent Solenoid scayetanot Vue Green Line 1 09-04-2017 05:40 PM
Which Vapor Canister Purge Valve does my Saturn use? saturn95 S-Series Tech 3 07-15-2014 04:03 PM
