Old 05-18-2021, 12:45 PM   #1
spizwhit
spizwhit is on a distinguished road
2008 VUE 3.6L
Default Power Steering Reservoir Screen
Hi,
I have a 2008 Saturn Vue XR w/ 3.6L v6. I have power steering whine, and have been trying to reduce it without replacing the pump.
I did a full flush and vacuum bleed, replacing with approved GM power steering fluid. This improved it some, but still did not fix it, so I tried adding some Lucas power steering stop leak, which seemed to remedy the problem for some reviewers. For me, it made the problem worse.
Since the lucas product is very thick, I thought maybe this would indicate that I have a clogged screen on my reservoir, but I haven't been able to figure out if the reservoir actually has a screen without removing the reservoir.
Does anyone here know if the reservoir has a screen in it? I'm thinking if it does, I'll first replace the reservoir to see if that helps, and then move on to the pump if that doesn't help. If the reservoir doesn't have a screen, I won't bother with it.
Thanks,
spizwhit is offline   Reply With Quote
Motor oil in Power steering reservoir Dsaturn L-Series Tech 14 06-09-2017 11:31 AM
New power steering pump arrived w/ broken reservoir Upstate Saturn S-Series Tech 6 12-03-2014 12:18 PM
Where the heck is the power steering Reservoir ? Silver Vue General Saturn Discussion 6 03-31-2012 12:03 AM
part number for power steering cap reservoir prioris S-Series Tech 6 07-27-2011 06:05 PM
brake fluid in power steering reservoir jlettiere Aura General 15 01-16-2009 11:31 PM
