Old 05-24-2009, 03:40 PM   #1
Fingolfin
Fingolfin is on a distinguished road
1995 SW2
Default Weird 1995 SW2 electrical problem
Hey folks,
I'm a newish owner of a 1995 SW2 with about 196K on it. It's a great car but it's got this little problem. If I start the car, say to pull it out of the garage, it'll start right up. Then when I put it back after I've finished in the garage, say 5-10 minutes later, it'll short out on startup. The lights on the dash will go nuts, I can hear the relays tripping under the dash panel on the passenger side, the engine will have started but peter out after running a touch rough, and the clock will go dead. If I disconnect the negative battery cable I can usually reset things and the car will start again just fine. Or if I let it sit for an hour or so, it'll start fine.
I can sort of reproduce this if I run the power windows when they're closed-- by putting a load on the motors to close when the windows are already closed will get the flashing dash condition, and the engine may stall (I don't do this one anymore, usually tempted to play with it when I'm driving!)
Could all this be cause by a bad window relay? Or the start solenoid, or a bad firewall ground? I cleaned up the main positive and negative body grounds, but still get this problem. I'd think it was the start solenoid, or even a bad battery cell, but otherwise it starts fine except in certain situations...
I hate car electrical with a passion, and so far these forums have been a great resource for me... can anyone give me some suggestions about what this might be?
Fingolfin is offline   Reply With Quote
Old 05-24-2009, 03:45 PM   #2
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
Default Re: Weird 1995 SW2 electrical problem
How old is the battery?
Are the battery cables clean of corrosion?
I would say; from what you describe; it sounds like you have an old battery in this car.
Get the battery tested at your favorite auto store and see what it the results are...it should read 12 Volts at a standstill, and with the car running (lights and interior heater) it should read 13-14 Volts (which would tell you that you have a good alternator).
I suspect the battery.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 05-24-2009, 06:20 PM   #3
Fingolfin
1995 SW2
I do too, but I want a couple opinions. No corrosion on the terminals. It's about 11.5 volts at standstill, about 13.2 when the engine is running. All that means is that the alternator is good... still could be a cell about to go, I s'pose. Thanks!
Old 05-24-2009, 06:48 PM   #4
2NDSOUT
2NDSOUT's Avatar
1994 SL2
1999 SL
Even if it's at 11.5 at a standstill...you should have 12 Volts without the car running, there is something that is drawing some current.
Replace the battery.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
electrical, stalling, starting problems, sw2
weird electrical problem with Ion 3 03 lunatius Ion General 5 06-05-2009 08:50 AM
Weird electrical problem....need help! Iemtall S-Series General 4 01-22-2008 10:11 PM
Weird Electrical Problem. redkees@msn.com S-Series Tech 7 04-08-2006 04:33 PM
1995 Sw2 Alternator Problem ???weird kbg1 S-Series Tech 5 08-27-2004 10:17 AM
Weird electrical problem in my 91 SC, please help 91SC Miscellaneous Tech 4 11-20-2002 04:51 PM
