Old 07-27-2021, 04:05 PM   #1
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default Trailing arm front bushing.
Is it possible to replace the front bushing in the trailing arm without completely removing the arm from the car ?
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 07-27-2021, 04:17 PM   #2
floridasl22002
Default Re: Trailing arm front bushing.
Short answer is I'm not sure. When I did the bushings on my son's L300 a couple of years ago. I did end up removing the trailing arms. It's a big doughnut type bushing that's a mix of rubber and steel.
If you can swap out the bushing with removing the arm from the car, that would be great as that arm is a heavy sucker.If you can that front of the ram to drop down enough, then it should be possible.
I removed my doughnuts with a mixture of blow torch to get rid of the rubber and a sawzall to saw across the steel bushing. Once it was split, it created just enough wiggle room to push it out. I got a bushing loaner from O'Reillys to install the new bushing. I always use dishwash soap as the lubricant to help them slide in better. It doesn't damage the rubber or the steel and simply gets washed off over time.
Trailing arm bushing Tyson L-Series Tech 4 10-02-2019 04:43 PM
Replacing front trailing control arm bushing RobertGary1 Vue Tech 6 12-14-2018 10:17 AM
trailing arm bushing fetchitfido S-Series Tech 1 04-05-2013 01:16 PM
trailing arm bushing 04 AWD rowdydog Vue Tech 2 11-01-2012 09:16 AM
Trailing arm bushing for '05 VUE Whiteline Vue Tech 1 11-02-2009 05:03 PM
