Old 08-04-2021, 06:12 PM   #1
rjc862003
rjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the roughrjc862003 is a jewel in the rough
Default 2.2L ECOTECH Timing tensioner
I know the original style tensioners are an issue on these cars my 07 ion 3 quad happens to have the original style
what is generally considered the _best_ part to replace it with
rock auto has the following part numbers available
CLOYES 95374
ACDELCO 12608580
CLOYES 95481
INA ZT0117 {#24430296} Adjuster
rjc862003 is offline   Reply With Quote
Old 08-09-2021, 10:12 PM   #2
jarvis1906
jarvis1906 is a jewel in the roughjarvis1906 is a jewel in the roughjarvis1906 is a jewel in the rough
2003 ION-2 Sedan
Default Re: 2.2L ECOTECH Timing tensioner
Based on the premise that the AC Delco 12608580 is GM original equipment, I'd go with the AC Delco. Keep in mind that in all likelihood, you'll see a "made in China" stamp on it, but it should stand up to the test of time if it's truly GM sanctioned equipment.
The other brands are aftermarket parts, and AM parts often don't handle the task of critical applications such as timing components. And those are the last kind of parts you'd ever want to see fail prematurely. But then again, there's always the possibility that the other brands are made by the same folks!
Decisions, decisions. Lol.
jarvis1906 is offline   Reply With Quote
Old 08-10-2021, 08:03 PM   #3
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Overwhelming consensus is Cloyes
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 08-10-2021, 08:06 PM   #4
lrbraner
If the AC Delco was so good it would not need to be replaced so soon !!!!!!
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 08-11-2021, 08:27 PM   #5
CLOYES 95374
ACDELCO 12608580
CLOYES 95481
I'd go with the Cloyes #95374. I used their complete timing component sets when replacing my timing chain and balance shaft chain. Everything worked well. The chains were tight and quiet. Keep in mind that some wear will exist on the guides and they could need replacement as well. Unfortunately, the only way to know if they need replacement is to remove them for measurement.
361K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. Sadly, B & H are proving me correct...too bad.
Old 08-12-2021, 11:22 PM   #6
rjc862003
my understanding is as far as the hydraulic tensioner goes the latest iteration of the Cloyes and the Delco parts are the same
its a quiet running motor after startup I am going to have the local dealer who I do a lot of IT work for change the tensioner out for the new style for 244.24 out the door
they quoted me 984.42 todo the entire set which is a bit out of my price range atm
not sure why my 2007 ion 3 has the old style my understanding was they replaced the original flat headed style by the end of 2005? must have been built on a Friday or Monday
but I figure its smooth as butter except for that 2 second rattle on startup throw the tensioner in it and run it till it grenades' its got 130k on the clock and it looks like the previous owner kept up with the oil changes so I figure if I get anouther 20k out of it for the 2200 bucks I paid for it its more then good
I will of course have the tech inspect the timing set as best he is able while he hopefully has the valve cover removed todo the job(I really hope thats they way gm still recommends doing it) also will ask that the top guide bolt that haunted some early 2.2s be checked and replaced if necessary
I told them if they found anything seconds away from a catastrophic failure to replace it it all and I would find the money as it stands I don't plan on having them do the entire set as that is labor and dollar intensive
Old 08-12-2021, 11:46 PM   #7
FWIW, I was able to nearly eliminate the rattle at start up by adding HY-PER LUBE Oil Supplement at each oil change. The timing components were replaced at about 312K miles. Based on how much quieter the engine became after performing that job , I wished that I'd done it years earlier...oh well... My hunch is that with your current mileage your other timing components are in otherwise decent condition. (I certainly hope that I'm correct about that!)
Be sure to let us know how things turn out with the replacement of the tensioner. It helps everyone with these engines here at SaturnFans to know of your experience.
Old 08-13-2021, 10:14 AM   #8
rjc862003
Service is scheduled for Thursday the 19th at 8:00 a.m. we'll see if they kill my motor or not
Old 08-16-2021, 07:58 AM   #9
goaliemo
goaliemo will become famous soon enoughgoaliemo will become famous soon enough
2003 ION-1 Sedan
2006 ION Red Line
Cloyes is the original timing kit for these cars
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
goaliemo is offline   Reply With Quote
Old 08-19-2021, 11:02 AM   #10
rjc862003
Tensioner Replaced, dealer opted to do it without pulling the valve cover and ended up going magnet fishing when it came apart in pieces
luckily nothing dropped into the pan or timing set
Old 08-20-2021, 06:41 PM   #11
rjc862003
startup rattle has been 100% eliminated with the new tensioner
Old 08-22-2021, 12:08 PM   #12
Excellent!
Timing Tensioner Bad...Again! :( truck1985 Ion Tech 5 10-12-2012 07:48 PM
timing tensioner help please smokinscott1977 L-Series Tech 1 03-23-2012 12:25 AM
Look at this tensioner, need help with timing PLEASE. Liverpoolslover L-Series Tech 6 07-21-2010 11:50 AM
2.2 ecotech saturn vue timing chain replacement HELP! BassBoxMan Vue Tech 5 04-06-2008 10:54 AM
Timing Tensioner 93sc2owner S-Series Tech 2 07-22-2006 10:46 PM
