Old 07-28-2021, 08:27 PM   #1
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default 02 L300 rear spring
So i have an opportunity to test out my own advice regarding L series rear springs.
I have advised other members that the available 03-05 springs should work fine on their 00-02 L series.
The right rear spring on my 02 L300 broke the other day.
The only local JY spring I could find was from an 03.
So this weekend I will install it and see if there any issues.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 07-29-2021, 08:39 AM   #2
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default Re: 02 L300 rear spring - rear spring conundrums
hi ibran- looking forward to whether your jy 03 L spring actually works. makes logical sense that it would . my 01 just hit 191k and running well like a bad mofo. figure one of the rears will bust around 200k. hope it doesnt when eluding coppas on a tobacco road at 2a. strange that rear coils from a very similar chevrolet model- the malibu dont work. that car has the same ecotec 4cyl as the saturn L 100. any additional thoughts ? thanks tons bob f
Old 07-29-2021, 02:00 PM   #3
One search shows GM rear coil springs are available and fits 3.0L and 2.2L sedans and wagons from the list shown; https://www.gmpartsstore.com/oem-par...xoC9coQAvD_BwE
https://www.dejchevyparts.com/p/Satu...hoCknsQAvD_BwE
I've wondered if front coils are similar for both L-series and rear coils similar for both L-series.
Old 07-31-2021, 06:43 PM   #4
lrbraner
Yes they are available.
They fit 03 thru 05. The question is; will the work in a 00-02 ?
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 07-31-2021, 06:51 PM   #5
lrbraner
Replaced my 02's broken right rear spring with a left rear assembly from a 03 sedan.
No problems were encountered.
A couple of observations, the JY's list the rear assemblies as right or left.
They are in fact the some, and interchangeable.
The 03 spring coil OD is bigger than the 02 coil OD.
11mm vs 12mm. Number of coils are the same. Could not compare free length.
Surprisingly the ride height is virtually the same.
To summarize; 03 and newer rear springs can be used on 00-02's with out issues.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 07-31-2021, 09:17 PM   #6
02 LW300
02 LW300's Avatar
Thank you and happy it works for you.
2002 L200/5 Loaded, over 1/4 million miles!
02 LW300 is online now   Reply With Quote
2001 Saturn L300 (L81/3.0L V6) - Rear Camshaft Cover + Rear Guard/Mount [Removal] BrandonKastning L-Series Tech 15 04-07-2021 01:04 AM
LW 200 rear brake spring Al10453 L-Series Tech 4 10-21-2018 11:56 AM
Rear Spring Upgrade doc111054 Ion Tech 4 07-01-2014 03:09 PM
rear spring broke iheartmysaturn S-Series General 14 05-20-2006 04:19 PM
rear spring install steve69 Vue General 8 04-13-2006 02:38 PM
