![]() Join Date: Aug 2017
not sure where to post this but I am in need of a good s series tech not sure if there is anyone in the st Louis Missouri aera on the site that know of anyone
![]() Join Date: Apr 2014
2002 SL1
What's the issue you're having? Saturns are pretty simple cars and this forum has a wealth of knowledge and people who can help walk you through diagnosis and repair.
2002 SL1 5 speed - 165,xxx - Current daily 1993 SC2 5 speed - 200k - Unfortunately sold 2002 Silverado Z71 - 185,xxx 2007 Impala 3.5L - 365,xxx - Still running good, daily backup |
Its a 1999 sw2 automatic the car has a shifting problem so i had a rebuilt trans installed still have the same problem they said it must be something electrilal or ecm problem i am not good with this type of repairs was hoping to find a saturn guru in my aera
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
I would focus in on the valve body. I'm not 100% sure what is involved in rebuilding a transmission but if they didn't do anything to the valve body, that was likely the original issue. They would have likely torqued the input shaft nut as part of the rebuild. Ask them what was done to the valve body in the transmission rebuild.
If the maintenance schedule for transmission fluid and filter changes are not followed the valve body passages tend to get clogged up. The issue first presents as a delay and slam when going into reverse known as reverse slam. If not attended to right away then the input shaft nut losses torque and backs off. Eventually you start losing other gears. If reverse slam is caught early you can follow Wolfmans Reverse "Slam" Cure in Saturn Autotransaxles. If not caught early then you are in for valve body replacement and a retorque of the input shaft nut.
1999 SL2 MT (311,300 km @ 01/2023) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#5 |
They said they did all the updates on the valve body with the updated valve
![]() ![]() Join Date: Mar 2001
Unless they replaced the shift solenoids and line pressure solenoid I would start there. Pretty much all you need is an ohm meter and a diagram on the trans electrical connector.
Who did the trans? btw, I'm in the stl area. Highmile '95 SL1 767k and counting |
#7 |
Pm sent
Fan repalcement (moved for L-series Tech) | cginstructor | S-Series Tech | 1 | 08-20-2008 11:40 PM |
Saturn vue vs. S-series (tech aspect) | junker | S-Series Tech | 8 | 02-11-2008 06:05 PM |
New S-Series Forum - post S-series tech issues there? | coolgreany | General Saturn Discussion | 0 | 05-13-2003 11:28 PM |
Tech bulletin on 01 S series brakes? | Anubis | Miscellaneous Tech | 5 | 08-12-2001 11:59 PM |
Saturn -S- Series tech. tip | danielwau | Miscellaneous Tech | 0 | 12-31-2000 02:51 PM |
