Old 10-09-2016, 08:43 PM   #1
Jm1080
Jm1080 has a spectacular aura aboutJm1080 has a spectacular aura aboutJm1080 has a spectacular aura about
Default Help 1999 sl2 won't start
Car was running fine then just suddenly died and has not started since. It cranks but does not even attempt to start. I had it towed home and since replaced plugs, wires, coils, ignition module, cps sensor, and ignition switch. none of this has made one bit of difference. The battery is good. I can hear the fuel pump kick on and checked the fuel pump relay am I missing something any suggestions? Please help I'm out of ideas! It is a 1999 Saturn sl2 stick shift Thank you
Jm1080 is offline   Reply With Quote
Old 10-09-2016, 09:00 PM   #2
billysvue
Default Re: Help 1999 sl2 won't start
maybehttp://www.saturnfans.com/forums/sho...d.php?t=149360
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 10-09-2016, 09:02 PM   #3
Hearing the fuel pump is only an initial troubleshooting guide. This does not verify injector operation, spraying pressurized fuel thru each injector. Spark is another test. One or the other may be missing and one way to tell would be spraying starting fluid into the throttle body and see if the engine starts up. With several failed starting attempts, keep in mind the battery may run down. Recharge the battery. You can remove spark plugs to examine them for fuel as several failed starts should have plugs soaked in fuel.
Are there any blown fuses?
Old 10-09-2016, 11:58 PM   #4
Jm1080
Ok i will try that tomorrow. The plugs do have fuel on them i put the battery on the charger just in case. I don't think it's getting spark but what could be causing that after all I've changed? Thank you
Old 10-10-2016, 01:15 PM   #5
Jm1080
Got it started thank you very much for the ideas. It was a blown pcm fuse.
1999 sl2 no start-now mhorning S-Series Tech 15 10-15-2014 11:03 AM
1999 sc2 won't start unless Eaglefixer S-Series General 4 02-19-2010 01:08 PM
1999 SC2 won't start. etothepii S-Series Tech 12 03-12-2008 12:20 AM
1999 SL2 Wont Start/Hard to Start in Hot Weather BlueOgre S-Series Tech 9 06-28-2007 06:36 AM
No start 1999 SC2 Stumped99 S-Series Tech 3 04-09-2007 11:42 AM
