Old 11-22-2006, 02:40 AM   #1
IonPA
IonPA is on a distinguished road
IonPA's Avatar
2003 ION-1 Sedan
Default Battery change 2003 Ion
I had my ignition switch fixed today at saturn ($190) for my 2003 ion.
They said my battery failed the test and wanted $115 to install a new one.
I passed. I know its cheaper at Sears or some place similar but i am curious.
How hard is it to install a new battery myself?
Where do I look on the battery to find its model #?
Anyone recommend a specific brand?
Thanks
IonPA is offline   Reply With Quote
Old 11-22-2006, 03:48 AM   #2
papado1
papado1 is on a distinguished road
papado1's Avatar
Default Re: Battery change 2003 Ion
I paid $95.00 for new one about a month ago and I installed it myself. This battery is not an ordinary one that you can buy from Sears or any other auto parts store , it has vents coming out of the side of the battery that connect to two exhaust hoses that expel built up gases from entering into the car.
One of the things that we have to trade off for not having the battery in the engine compartment.
papado1 is offline   Reply With Quote
Old 11-22-2006, 07:56 AM   #3
THX712517
THX712517 is on a distinguished road
THX712517's Avatar
Expect to pay about $85 for the battery plus tax, and then however much they charge for putting it in. papado1 is correct, it's a special battery, a 75-group vented battery. It has two vents to which are attached hoses/tubes that allow hydrogen gas buildup to vent outside the car. Do not get a conventional battery, otherwise you'll be riding around with a potential bomb placed conveniently close to your fuel tank.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
THX712517 is offline   Reply With Quote
Old 11-22-2006, 10:57 AM   #4
NOLA-Vue
NOLA-Vue is on a distinguished road
2008 AURA XE
2006 VUE 2.2L
Another thing to think about is that the OEM battery is a sealed-top Delco maintence free type. Most all other types have vents on their top, and that kind almost always burp or "leak" battery acid through those vents, eventually. Since the ION battery is in your trunk, it is very possible that a top vented battery could eventually "leak" and cause corrosion in your trunk.
I don't know of anyone other than a Saturn retailer or Pepboys that sells them around here. At any rate, a Delco battery would be the only one that I would consider for replacement.
"The principle difference between a man and a dog is that if you take a dog in and make him prosperous, he won't bite you!" - Mark Twain
2008 Aura XE-4
2006 VUE 2.2L
NOLA-Vue is offline   Reply With Quote
Old 11-22-2006, 01:22 PM   #5
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
Great! Now you've tipped off the terrorists! ......................
daver is offline   Reply With Quote
Old 11-22-2006, 01:37 PM   #6
HeroHog
HeroHog is on a distinguished road
HeroHog's Avatar
2007 ION-3 Quad Coupe
I would assume you could use one of those new "sealed" high-performance batteries like the Optima but could be wrong. I also see they ain't cheap!
HeroHog is offline   Reply With Quote
Old 11-22-2006, 07:39 PM   #7
CarNut
CarNut is on a distinguished road
2004 ION Red Line
I got one for under $100 at Sam's Club. It's an Exide brand though. Optima is usually $130 plus.
CarNut is offline   Reply With Quote
Old 11-27-2006, 03:44 PM   #8
jess3292
jess3292 is on a distinguished road
2003 ION-3 Sedan
Where is the battery located on the 2003? I assume from the posts that it is in the trunk somewhere???
I am having some flickering light problems in the car and just assumed that the battery at this point might be a good start and a safe decision after 3-4 years....
jess3292 is offline   Reply With Quote
Old 11-27-2006, 06:00 PM   #9
THX712517
THX712517's Avatar
In the trunk, hence my comment earlier about the fuel tank. Get into your trunk, lift up the floor panel, you'll see your spare and your battery bolted down there. I got a new one for my car after three years and there really wasn't a noticeable difference. It's protected from heat, and if you drive every day it gets charged up. Battery's got potential for a very long life span. If you're concerned about it, have someone test the voltage. Should cost a lot less than a new battery.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
Old 12-01-2006, 03:24 PM   #10
mr weather
mr weather is on a distinguished road
Yeah, heat is what kills a battery. Putting it in the back not only balances the vehicle weight a little bit but also keeps it away from the heat of the engine.
mr weather is offline   Reply With Quote
Old 12-09-2006, 12:59 PM   #11
Crawdaddy
Crawdaddy is on a distinguished road
Crawdaddy's Avatar
2005 ION-2 Sedan
2003 VUE 2.2L
not to mention making it easier to wire car audio amps up to, and giving the motor engineers more space to play with I just wish it was a top post battery, so much easier to deal with...
Crawdaddy is offline   Reply With Quote
Old 12-09-2006, 01:30 PM   #12
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
Originally Posted by THX712517 View Post
...Battery's got potential for a very long life span. If you're concerned about it, have someone test the voltage. Should cost a lot less than a new battery.
I'd just recently picked up a "Smart" Battery Charger which can do much of the basic Battery testing and diagnostics right at home and can also do an Alternator check. So while I'd fully agree if you are worried about the battery condition AutoZone and other parts stores offer FREE diagnostics... I'm very happy with my $35 "upgrade" to a Charger that can give me a fast charge and tell me of problems BEFORE getting a second opinion at a Battery Store.
I'm also very glad for this (and others) post's discussion of the ION's "vented" Battery. I hadn't really thought about it till today. Hopefully, if someone where to look up the required Battery Type for the ION the books have some kind of "warning"... Model XXX Vent type. Not just a "75-group" listing and the Clerk just picks up and drops in any old battery that will fit.
Hopefully the vent tubes and such they will need to remove (not to mention it's location) will clue them into the fact this battery must be different from a typical engine mounted battery.
lgodave is offline   Reply With Quote
Old 12-09-2006, 07:38 PM   #13
mr weather
Absolutely! Nice being able to have short fat runs of cable.
Battery Change ers S-Series Tech 12 12-28-2009 09:07 PM
How do I change front wheel bearing on the 2003 Ion? jonnyek Ion Tech 7 07-17-2008 07:24 PM
2003 ION 3...got an oil change, now my engine is shot grindstevehxc Ion Tech 13 04-28-2008 11:01 AM
How do I change the battery silenced Ion Tech 4 01-23-2007 01:07 AM
Anything else I need to change the battery? Lurker1999 Miscellaneous Tech 5 12-22-2004 12:45 PM
