Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 09-24-2005, 11:47 PM   #1
Zorak
Zorak is on a distinguished road
Zorak's Avatar
Default holes gouged out
on you guys's's bored TBs, are the vacuum line holes opened up to large sizes because the boring process carved the wall thickness down?
Zorak is offline
Old 09-25-2005, 09:23 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: holes gouged out
I had a crappily done throttle body with the vacuum holes scraped out. bad. The JG one I got from SPS was done correctly without ruining those holes. They enlarged the throttle body in front of the throttle plate and enlarged the throttle plate area but left the rest of it alone. It's tapered 56 mm to 52 mm at the throttle plate.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 09-25-2005, 11:52 PM   #3
Tycho
Tycho is on a distinguished road
Tycho's Avatar
Doesn't matter what size those holes are, the vacuum line itself is the restriction.
On all the 55mm TBs I've done and run the holes have been nixed and they've all worked great (passed CARB and everything).
Forced induction is rape.
Tycho is offline
Old 09-25-2005, 11:57 PM   #4
Zorak
Zorak's Avatar
good that gives me some confidence and i'll continue lathing those suckers outta there
Zorak is offline
Old 10-01-2005, 12:47 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
my crappily done one leaked at the vacuum lines and no amount of silicon goo or jb weld helped. the pcm doesn't like vacuum leaks at the thottle body at all. the first clue was when it began to idle at 4000 (four thousand) rpm... d'oh.
eRic 02sc2
Old 10-01-2005, 12:11 PM   #6
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
I dont have my vacuum lines hooked up....
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
the_skin_eater is offline
Filling the holes 4dhtrs S-Series Tech 4 10-22-2005 04:32 PM
holes saturnsctwo S-Series General 11 07-19-2005 03:36 PM
RL front disk rotors gouged motorheadkev Ion Red Line 9 11-08-2004 06:02 PM
hood changes, holes - no holes ?? sc2_94 General Saturn Discussion 1 11-01-2002 10:46 AM
Using only 3 holes instead grinnen30 Miscellaneous Tech 1 05-11-2002 09:31 PM
