Old 07-18-2005, 04:43 PM   #1
saturnsctwo
Default holes
i have a 2001 sc2. when you open up the hood, right next to the hood hinges on both sides there is a hole that has tape over it. they are small holes like for a bolt or something why are they covered with tape? if the tape comes off, will i get leaks into the car?
Old 07-18-2005, 04:56 PM   #2
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
Default Re: holes
OH MY GOD, DON'T EVER TOUCH THOSE!
Naw, just kidding! Doesn't look like anything really weird would happen if you removed the tape, but why? Do you want to use them for something?
dansl2 is offline   Reply With Quote
Old 07-18-2005, 05:00 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: holes
I would think it'd be good to keep water out if they felt need to tape it...
Old 07-18-2005, 06:49 PM   #4
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: holes
holes in the hood, or at the bottom of the windshield cowl?
M.Nguyen is offline   Reply With Quote
Old 07-19-2005, 09:43 AM   #5
saturnsctwo
Default Re: holes
lol! actually the tape is starting to pell off slowly around the edges, but the seals are not broken as of yet. i'm not using htem for anything, but i just wondered why they are covered & if left uncovered will they leak....
Old 07-19-2005, 09:45 AM   #6
saturnsctwo
Default Re: holes
the holes are right next to the hood hinges (the hinge part that bolts to the car, not the hood) they have black tape over them.
Old 07-19-2005, 09:48 AM   #7
saturnsctwo
Default Re: holes
but if the tape is meant to seal them off, why just use tape which would for sure peel off like mine is starting to do slowly? why not use a rubber grommet or a like item?
Old 07-19-2005, 12:20 PM   #8
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
Default Re: holes
Last time I detailed my engine I accidently put a finger through one of those. I just used some goo-gone and got it completely off. I will be replacing it with a more robust plug.
cloud819 is offline   Reply With Quote
Old 07-19-2005, 12:31 PM   #9
M.Nguyen
M.Nguyen's Avatar
1993 SL2
Default Re: holes
If they're the ones im thinking of (about 1.5'x3' oval) then they should be exposed, but covered with a foam piece and mesh.
Old 07-19-2005, 01:11 PM   #10
saturnsctwo
Default Re: holes
no, those are those vents. those also came off my car, but i re-glued them. the holes i'm talking about are just small holes around maybe 1/4" or so...
Old 07-19-2005, 03:24 PM   #11
dansl2
dansl2's Avatar
2000 SL2
Default Re: holes
Mine are in the same shape. Looks like the tape is beginning to peel also. I don't think water gets to that area (at least they don't look like they've ever gotten wet to me). I just figure that at some point, there was going to be tubes or something going through there for something I haven't thought of yet. Maybe a super-soaker windshield washer sort of thingie?
Old 07-19-2005, 03:36 PM   #12
saturnsctwo
Default Re: holes
i'm sure they would get wet. you can see them when the hood is closed between the hood & windshield. especially when you wash your car. what's interesting is i e-mailed saturn & the dealership & nobody seems to know what they are for, & some don't even know what i'm talking about....
Filling the holes 4dhtrs S-Series Tech 4 10-22-2005 04:32 PM
holes gouged out Zorak Mods and Performance 5 10-01-2005 12:11 PM
Spoiler Holes SlimSaturn Ion General 12 02-18-2004 11:21 AM
hood changes, holes - no holes ?? sc2_94 General Saturn Discussion 1 11-01-2002 10:46 AM
Using only 3 holes instead grinnen30 Miscellaneous Tech 1 05-11-2002 09:31 PM
