Old 06-14-2021, 12:38 PM   #1
SL1Noob
SL1Noob is a jewel in the roughSL1Noob is a jewel in the roughSL1Noob is a jewel in the rough
Question Rear Subframe trailing arm rot.
I have a 1996 Saturn sl2 that failed inspection because of the trailing arm frame rot.
I have some questions about the frame really.
Can the rear frame be removed so that I can try and fix it? If so is there any tutorials out there to that, I couldn't find any.
I have put so much into this car that I would hate to trash it because of rust. I could remove the subframe I think I could fix it, but my neck won't allow me to be under a car for much time, so i thought maybe be removing it and fixing it might be the way to go.
SL1Noob is offline   Reply With Quote
Old 06-14-2021, 12:53 PM   #2
billr
Default Re: Rear Subframe trailing arm rot.
I'm pretty sure the rear is non-removable.
Old 06-14-2021, 01:18 PM   #3
SL1Noob
Happy Re: Rear Subframe trailing arm rot.
I just went and jacked it up and looked at it.
This part where the trailing arms connect to does NOT removed. It is part of the unibody.
That being said, it looks like the structural part where the actual trailing arms connect too are good. So that is a win. I can now understand why this rusts out so bad, it is a HORRIABLE design. If I can, I will improved on the structural cover they made. I will try and post pictures soon.
Time to break in the cheap ass mig welder and do a lot of grinding and cleaning.
Old 06-14-2021, 01:35 PM   #4
SL1Noob
So the pictures you're looking at is from the driver side and it's the initial on what it looked like when I looked at it and when I punched out what rust was loose just from using my thumb.
Images
http://imgur.com/gallery/LsqbQQ3
Old 06-14-2021, 02:23 PM   #5
Waiex191
Waiex191's Avatar
A couple of videos for you:
https://youtu.be/g6QdDvxVfCQ
https://youtu.be/-6sXv2uX9wg
And a thread:
https://www.saturnfans.com/forums/sh...d.php?t=266810
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 06-14-2021, 02:28 PM   #6
SL1Noob
Yeah, saw that first one.. mine is not that bad at all..
The actual part where the bolts are seems solid.. so i am going to cut out the bad.. clean up well, paint it.. and replace the plate that goes across the well.
Tags
frame, rust, trailing arm
Rear Trailing Arm I-4 S-Series General 7 01-02-2018 11:23 AM
Rear Trailing Arm Chaz9496 L-Series General 27 01-25-2017 02:09 AM
Right rear trailing arm cityhawk S-Series Tech 8 09-05-2014 01:31 PM
Rear trailing arm Charlie Classifieds 0 11-19-2013 12:57 AM
Rear Trailing Arm wrillo S-Series Tech 4 05-21-2013 10:16 AM
