Old 06-12-2021, 04:38 PM   #1
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Default Ignition switch replacement
Does anyone know if dropping the steering column will make enough room to unscrew and remove the switch?
OU812 is offline   Reply With Quote
Old 06-13-2021, 12:09 AM   #2
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Default Re: Ignition switch replacement
Your steer column may have a 'tilt' feature, of some use.
On different model years, I've moved the 'tilt' down, loosened the
longish bolts supporting the column, and even dropped the steer wheel
onto the forward edge of the front seat (do not drop steer wheel onto
front seat!).
The first impediment to removing the IgSw, is removal of the plastic
cover of the column in the area of the IgSw and the "combination
switch" which incorporates signaling, headlight dimming, hazard lights,
and wiper activation.
One needs a small/thin nut driver, something like 4.5mm or 5.5 mm....
to remove the plastic cover. The bolts supporting the column are accessed
from below, negotiating wire harnesses, etc.
Old 06-14-2021, 05:39 AM   #3
OU812
1996 SL1
I already removed the plastic covers and tilted the steering wheel i just want to know if dropping the steering column lower would make it easier to remove the ignition switch bolts
Old 06-14-2021, 09:11 AM   #4
Waiex191
Waiex191's Avatar
Are you talking about the screws that hold the actual electric switch to the lock cylinder, or the security bolts that hold the lock cylinder to the steering column? I've done both and I did not drop the steering column.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 06-14-2021, 09:23 AM   #5
OU812
1996 SL1
The screws that hold the switch to the back of the cylinder, i can feel them with my fingers
Old 06-14-2021, 10:40 AM   #6
Waiex191
Waiex191's Avatar
You should be able to just take them out.
Bryan Cotton
Old 06-14-2021, 10:57 AM   #7
OU812
1996 SL1
I want to know if the switch can be removed without removing the steering wheel , multifunction switch or the security screws and just reach behind it and unscrew it i watched the Richpin video and i am trying to avoid all of that
Old 06-14-2021, 02:25 PM   #8
Waiex191
Waiex191's Avatar
Yes Yes
(had to say it twice for the 5 character minimum limit)
Bryan Cotton
Ignition Switch Replacement , 2nd gen TomM96 S-Series Tech 3 04-10-2012 09:43 AM
ignition switch replacement ingledum Ion General 1 12-10-2010 04:24 AM
Need help with Ignition switch replacement spynet Ion General 3 12-21-2009 07:09 PM
99 SL ignition Switch replacement Q's matt93&04 S-Series Tech 2 04-03-2009 10:18 PM
Ignition switch replacement Toby Windsor S-Series Tech 2 05-17-2008 11:34 PM
