Old 02-21-2019, 01:40 PM   #1
ccbst10
ccbst10 is on a distinguished road
2000 SL2
Question Another 2000 Saturn SL2 cruise control installation
I understand I'll need the steering wheel, module, and to have the PCM re-flashed with the Cruise option enabled. It is my understanding that the cruise module goes right under the dash on the steering wheel neck. Can I get away with having them pull the PCM? It is a base SL2 with no power locks or power windows, would I need a PCM out of a car with the same configuration but with cruise? Where is the PCM located on the car? Thanks for any advice you can give!
ccbst10 is offline   Reply With Quote
Old 02-21-2019, 02:05 PM   #2
Default Re: Another 2000 Saturn SL2 cruise control installation
Swapping the gen-3 pcm is not worth the hassle/expense. It will be ultimately cheaper to find someone/chevy dealer than can reflash the PCM or just enable cruise.
Old 02-21-2019, 04:44 PM   #3
^ ^ ^ I've never swapped a PCM, especially on a 3rd gen.
I suspect at least part of the hassle is after a swap, there is some procedure involved to introduce the PCM to the 3rd gen's BCM. And hope that Passlock or whatever the security thing was called does not rear its ugly head.
3rd gen PCMs are located behind the battery, flat silver rectangle.
Not sure I would trust a junkyard guy to pull the right PCM with the right trans, etc. Some of them don't seem to pay attention to details, and the details can matter.
The richpin video shows the cruise module installation but as you already know, steering wheel is different
https://www.youtube.com/watch?v=EEUgba5xxnA
Old 05-29-2021, 10:21 AM   #4
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
My Gen 3 is hard wired for Cruise only, so it must be able to be Flashed for it with the original PCM. There's a mobile company that comes out and to a shop and does it, but it's $250 and with No Guarantee to work. I think once I get the module installed, I'll call around. Out of My price rage. BTW, anyone know why the Module Cable end has an adjustable "Zip Tie" type end on it ? Sorry for the late response to an old thread.
Old 06-01-2021, 09:09 AM   #5
trottida
trottida's Avatar
I replied to your other post regarding the programming. The zip tie provides the final adjustment of the linkage to the gas pedal. It takes up the slack so there is no delay in engagement.
1999 SL2 MT (298,000 km @ 06/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
2000 Saturn SL2 cruise control installation ASR89 S-Series General 135 08-03-2021 08:19 AM
cruise control installation racinginblood S-Series Tech 5 09-01-2011 11:05 AM
cruise control installation for 2002 SL1 sturgeon S-Series Mods 2 02-24-2010 01:21 AM
Cruise Control Installation Zvolen S-Series Tech 5 03-11-2008 11:51 AM
2000+ Saturn S-series cruise control diagram hookem202 S-Series Mods 0 12-15-2007 05:05 PM
