Old 08-24-2013, 06:12 PM   #1
iobrien
iobrien is on a distinguished road
Default 2008 Saturn Vue Purge valve canister solenoid location
My check engine light came on in my 2008 Saturn Vue, with OEM code P0496. Through a lot of googling and phone calls, I'm pretty sure I need to change the purge valve solenoid. I have the part in hand, the car on ramps, and tools out, but cannot find the part ANYWHERE! Can anyone tell me where to find the blasted thing so I can change it? Thank you!
iobrien is offline   Reply With Quote
Old 08-24-2013, 07:02 PM   #2
ruley73
ruley73's Avatar
Default Re: 2008 Saturn Vue Purge valve canister solenoid location
Which engine does your Vue have? Exactly which part are you replacing?
The canister purge solenoid will have two EVAP hose connections and is going to be under the hood somewhere. Exactly where depends on which engine you have. The canister vent solenoid is a long round part that goes into the canister. On our 2007 Equinox the canister (large, black plastic box) is under the vehicle just ahead of the fuel tank IIRC and yours should be in a similar location.
These parts have a relatively low failure rate, so be sure to inspect all the EVAP lines.
I will post a PDF with exact replacement instructions after you specify which engine you have and what part you are replacing.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 203K miles
2018 Chrysler Pacifica Touring L 68K miles
Old 08-24-2013, 07:13 PM   #3
iobrien
ruley73,
I am replacing the canister purge solenoid on a 3.5L V6 engine. Thank you so much!
Old 08-24-2013, 07:25 PM   #4
ruley73
ruley73's Avatar
It appears to be right in front of the throttlebody on the driver's side of the engine. You will need to remove the intake manifold cover to get to it - just remove the oil filler cap and pull up.
2008_Vue_3.5L_evaporative-emission-canister-purge-solenoid-valve-replacement.pdf
Old 08-25-2013, 12:35 AM   #5
iobrien
Thank you!!! Found it!!
Old 03-12-2014, 05:36 PM   #6
lscarbrow
lscarbrow is on a distinguished road
2008 VUE 3.6L
is this a common issue? i have a 2008 vue with the 3.6L reading the same code...is the purge valve solenoid in the same location on this engine?
lscarbrow is offline   Reply With Quote
Old 05-03-2014, 10:22 PM   #7
jwlamb
jwlamb is on a distinguished road
Attachment 34741
That pdf is for the 3.5L, do you have the instructions for the 3.6L?
Thank you!
jwlamb is offline   Reply With Quote
Old 05-04-2014, 10:20 AM   #8
far2grumpy
far2grumpy's Avatar
Thank you!
I have PDF for 3.6 - slightly too large to post (350 Kb) - PM email address if you can't locate otherwise.
Old 05-04-2014, 12:59 PM   #9
ruley73
ruley73's Avatar
Thank you!
I've attached instructions for the 2008+ Vue w/3.6L.
2008_Vue_3.6L_evaporative-emission-canister-purge-solenoid-valve-replacement.pdf
Old 08-08-2016, 11:51 AM   #10
saturn09vuev63
saturn09vuev63 is on a distinguished road
Will this pdf work for a 2009 saturn vue XR front wheel drive, v6 3.6 engine also?
Thanks.
saturn09vuev63 is offline   Reply With Quote
Old 08-11-2016, 12:40 AM   #11
ruley73
ruley73's Avatar
Thanks.
Yes, the 2008 3.6L Vue PDF should be applicable to all 2008-2010 Vue w/3.6L engine.
Canister purge valve location 06 vue grimesd Vue General 1 03-28-2013 10:23 AM
Canister Purge Valve Solenoid prioris S-Series Tech 8 03-14-2013 08:03 PM
EVAP canister purge solenoid location CA-Legal-Vette S-Series Tech 3 10-19-2008 05:41 PM
CCPS (Carbon Canister Purge Solenoid) location? xupthree60 S-Series General 2 03-25-2006 02:05 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
