Old 04-03-2013, 01:57 AM   #1
nwgator
nwgator is on a distinguished road
1997 SL1
Default AC service port caps
Does anyone know the part numbers for the caps on the AC service ports, or will generic ones work? The cap on my high side is broken, so I might as well replace both while I'm at it.
nwgator is offline   Reply With Quote
Old 04-03-2013, 02:45 AM   #2
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Default Re: AC service port caps
They are generic and available at any autoparts store.
Old 04-03-2013, 05:24 AM   #3
PlasticCarsRock
PlasticCarsRock's Avatar
Yes. However, many of the generic ones do not come with o-rings, so be sure to get some o-rings to go with them, if yours are not in good condition (the o-rings in the cap form the main seal: the quick connect valves all seem to leak, slowly).
low side pressure service port location, 2003 L200 sean123 L-Series Tech 3 07-23-2017 02:01 PM
Is the high side A/C service port a one way port? MadPuppy S-Series Tech 8 06-14-2012 06:02 PM
ODB Port? hrb5711 Astra Tech 4 02-02-2009 04:19 PM
where/how to put in a usb port into the vue (for the nav) Counterfit Vue General 10 06-22-2008 11:05 PM
To port or not to port mod96sl2 Miscellaneous Tech 8 02-28-2003 09:35 PM
