Old 01-18-2010, 05:15 PM   #1
dcc81187
dcc81187 is on a distinguished road
1996 SC1
Default Belt Question
Correct me if I'm wrong but it looks like i should be able to use a different belt and bypass the ac compressor pulley on my 99 sc2 with no problems. I was wondering if any of you guys would happen to know the part number for the smaller belt that would be required? Thanks
dcc81187 is offline   Reply With Quote
Old 01-18-2010, 11:10 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Belt Question
I put short belt on my 92 SC to bypass the A/C after I removed the A/C. this was back in 1993 and I do not remember the part number. ask a Saturn retailer before they close.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-19-2010, 09:29 AM   #3
wrenchtnr
wrenchtnr is on a distinguished road
1992 SL
Go to your auto Parts Store, ask for a belt for your car, when they ask if it has A/c tell them NO. Their computer will tell them the correct belt to sell you.
wrenchtnr is offline   Reply With Quote
Old 01-19-2010, 10:57 AM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
I'm not sure the SC2 was offered without air. I would ask about a base SL for the same year instead.
SaturnSeries.net owner
Old 01-19-2010, 11:25 AM   #5
The SL didn't have power steering, so that belt wouldn't work. An SC1, SL1 or SW1 could be gotten with power steering and no A/C, but I *THINK* the crank pulley was a slightly different size, either that or the P/S pump is in a slightly different position (since it hangs on the head); generally, I'm pretty sure the belts for DOHC engines are slightly longer than their counterparts for SOHC engines with the same pulleys.
A/C was standard on all DOHC models, but there was an "A/C delete" option.
The OP will save next to nothing simply running a shorter belt. When the A/C is off, the compressor clutch is disengaged and the pulley is, in effect, an "idler". S/he would gain more advantage from the weight savings by removing the A/C components from the car (not to mention the easier access to things like the thermostat).
Old 01-19-2010, 01:07 PM   #6
dcc81187
1996 SC1
I dont want to remove the a/c I'm going to put the regular belt back on when it gets warm. I just see this as an easy way to remove some drag on the motor, I know it wont be much but as the temp drops every little bit helps.
Old 01-19-2010, 05:04 PM   #7
wrenchtnr
1992 SL
Yeah, I was going to ask why you were doing it. The amount of fuel you'll save by not spinning the a/c pulley will not offset the cost of the new belt. Plus you will not have defrost function.
Old 01-19-2010, 05:08 PM   #8
S/he doesn't anyway, as the A/C doesn't run at ambient temperatures (as reported by the IAT sensor) below 40F, and the gen-1/2 HVAC systems do NOT automatically run the A/C in defrost mode. But indeed, the savings wouldn't pay for the belt.
Belt Question Helltime S-Series Tech 1 03-02-2009 08:02 PM
Timing Belt Question hufhouse L-Series Tech 13 12-31-2007 06:49 PM
belt question again 00satSC1 S-Series Mods 6 10-15-2006 03:25 AM
Serpentine Belt Question 20VUE06 Vue General 0 05-31-2006 04:30 PM
Serpentine Belt question.... gm7 S-Series Tech 6 08-08-2004 10:11 PM
