Old 06-10-2021, 10:54 AM   #1
flyhop
flyhop is on a distinguished road
2000 SL2
Default Need a new key!
2000 SL2, 185000 miles, Auto-tragic.
We are third owners. No fob, no original key. Using copy handed to us. Yes, I know I should have kept that as a master, but that time has passed.
Key is really worn down, and I'm thinking it has little time left. So, I'd like to get a new key/ignition or new key made from existing.
I don't know where to start (every pun intended) or even what options are possible.
Can I pull the ignition switch and take it to a locksmith to have a new key cut? Can I call the dealer and see about getting a GM key? eBay? Teacher so trying to avoid any major expense on a 21 year old car.
Thanks in advance.
flyhop is offline   Reply With Quote
Old 06-10-2021, 11:44 AM   #2
trottida
trottida's Avatar
Default Re: Need a new key!
Take your ownership to a GM dealer parts department and tell them you would like to have a key cut from VIN. This should cost anywhere from $10-$20 based on others documented within this site. This will get you the best results with the least amount of work.
1999 SL2 MT (298,000 km @ 06/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 06-10-2021, 12:07 PM   #3
flyhop
2000 SL2
Thanks! And....wow! Do I hope it is that easy.
I'm calling them today!
Old 06-10-2021, 02:26 PM   #4
flyhop
2000 SL2
Called stealership. Proof I own it and $30 **zoinks**, I can get a new key. Easy peasy. Thanks.
Old 06-10-2021, 02:52 PM   #5
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
2000 SL1
It's $30 now for a dealer key? Are you buying their lunches too? Damn...
Check out my current SL1!
http://www.saturnfans.com/forums/showthread.php?t=268456
cujoe_da_man is offline   Reply With Quote
Old 06-10-2021, 04:14 PM   #6
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
1996 SC2
Now go down to a lock smith and make a copy. The $30 is your lifetime virgin to make copies from.
Old 06-11-2021, 01:07 AM   #7
sc2 saturn
sc2 saturn will become famous soon enough
i bought my keys online from CLKsupplies and went to gm dealer ship and they cut the key for my vin and costed me nothing which your key is a B96-P at CLKsupplies there $1.02 ea I've used this website for years they carry everything fobs keys etc
sc2 saturn is offline   Reply With Quote
Old 06-11-2021, 07:19 AM   #8
laser3kw
laser3kw will become famous soon enoughlaser3kw will become famous soon enough
2000 SC1
I was in the same situation a couple of years ago. I went to a local locksmith, took my plate registration in (for the vin number). 30 minutes later I had new keys. Simple as that. Cost may vary.
laser3kw is offline   Reply With Quote
Old 06-11-2021, 11:50 AM   #9
flyhop
2000 SL2
Followed through on Laser's suggestion of a Locksmith.
One I called suggested I stick with Dealer for VIN key cut.
Just FYI.
Old 06-11-2021, 02:54 PM   #10
trottida
trottida's Avatar
Just FYI.
I think he meant to take your new dealer cut from VIN key and make a copy or two at a locksmith or hardware store. Keep the dealer cut one tucked away in case in the future you have to replace your worn key. Use the copies for everyday until they are worn.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 06-11-2021, 05:55 PM   #11
laser3kw
2000 SC1
Just to be clear - I had the locksmith cut new fresh keys using the vin number only. The locksmith did not copy an existing key. He input the vin into his software and it cut the key to the specs for that vin.
Old 06-13-2021, 12:17 AM   #12
TomM96
Some locksmiths lack the SW.
Some may not know which blanks will work.
Best bet is a cut from VIN, which all dealers, and some locksmiths, do.
Then, as suggested, have a copy made for daily use.
