Old 05-07-2021, 07:25 PM   #1
Undertake72
Undertake72 is on a distinguished road
Default 1998 sc2 tach issues still
Ok so here hopefully one last time .. I have the autometer model 2300 tach ...then was told I need the tach adapter to make it read properly .. Bought that .. But for the life of me i CANT get it to work at all ...any help would be appreciated very much .. Tach adapter model number 9117
Undertake72 is offline   Reply With Quote
Old 05-08-2021, 12:15 AM   #2
Default Re: 1998 sc2 tach issues still
Tach Adapter
Red -> +12v
Black -> Ground
Red/Green -> Tach signal from PCM (white wire)
Gray -> Gauge
M2300 Tach
4cyl = both DIP's down
White -> Grey wire on radio harness (or +12v if you want the backlight on all the time)
Red -> +12v
Black -> Ground
Green -> Gray wire from adapter OR White wire from PCM if not using adapter
All +12v references are key-switched sources, not directly from the battery otherwise it'll drain the battery.
Old 05-08-2021, 12:33 AM   #3
Maybe I'm reading the Autometer info wrong, but I don't think the above is correct. I think the 9117 goes in series with one of the ignition wires, after it the wire is cut.
What does Autometer say about all this? Do they understand that you are trying to connect to a Saturn wasted-spark system? If they cannot figure out why it won't work, I would abandon Autometer and start over. Trying to "finish the engineering" for a flaky vendor is not often a practical effort.
However, I suppose I should ask: what does it do now, no tach action at all, or still wrong reading? How, exactly, do you have the wires to the 9117 connected to the car?
Old 05-08-2021, 02:03 AM   #4
Undertake72
Autometer wasnt a great source of help ..they told me to hookup the red wire onto the brown with white tracer off ignition module with the tach adapter then put the red / green wire from adapter to the pcm side of brown/ white wire ...then it should work ...not working at all ...that wire with just the tach reads only 1 cyl ....wtf lol
Old 05-08-2021, 12:31 PM   #5
So, it is reading, but at 1/4 the proper rpm?
I'll check out the wiring connections you described and post again later.
I just re-read you last post, I think it is incomplete. You describe how you connected the RED wire and the RED/GRN wire from the 9117 adapter, but I think there are more than two wires from the adapter (4 of them?). How are the other adapter wires connected, and can I assume the adapter is connected to the ach as shown in the (again, poor) published Autometer info? I will post a link to the info I am referring to in my later post.
Oops,,, no need to post the Autometer info, that was already done in reply #2 by somebody else! Time to study some more now...
Old 05-08-2021, 09:39 PM   #6
Undertake72
Ok so on my tach adapter "per autometer" I connected the red/ green wire to the ignition module side .. Then the red wire to the pcm side of the brown/ white wire then I got no signal at all at tach ... Brown/white wire is cyl 4 signal output .. With adapter tach didnt work ... Without adapter I got 1/4 signal ... The white wire at the module I got half the signal on tach .. Havent tried the adapter on that wire yet ... But I'm not optimistic on that wire either ... Grrrrrrrr
1998 sc2 tach issues Undertake72 S-Series Tech 5 05-01-2021 12:09 AM
1998 sc2 tach siganl Undertake72 S-Series Tech 1 04-24-2021 12:05 AM
Speedo and Tach issues Ericth4 S-Series Tech 5 05-01-2011 08:27 PM
got a 1998 SC2 - some issues. genewitch S-Series Tech 41 05-17-2010 07:24 PM
Speedo/Tach issues Keeter S-Series Tech 1 10-11-2009 06:11 PM
