Old 12-06-2015, 05:37 AM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default step by step guide to install timing chain sl1 1995 plz
car type 1995 sl1 saturn sedan 4 door 1.9l Job timing chain.
Im searching on web for timing chain replacement from start to finish in the car . can it be done from the side is there enough room. Will a metric set of tools be about all needed? i have 3/16 bit too for the locking of the cam sprocket . What do i need to get all that accessory out of the way. How long does a job take. Since im a driveway mech i dont have lift to do a full engine removal but im handy on tools if i get the right information.
I should have no trouble . What orientation do the sprockets and the crank need to be locked in place during chain installation?
Packard is offline   Reply With Quote
Old 12-06-2015, 08:54 AM   #2
billysvue
Default Re: step by step guide to install timing chain sl1 1995 plz
Im searching on web for timing chain replacement from start to finish in the car . .?
THere are service manuals online- http://alldatadiy.com/
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 12-06-2015, 10:35 AM   #3
Crazy people have done it from the side and say it's not that bad of a job, me having an engine hoist says that thing's coming out because I can almost palm a basketball and the space provided between the cover and frame rail is designed for small people at best...
Chain tensioner: 168-in/lbs
Crankshaft: 151-ft/lbs (you'll need about 5x that much to get it off...)
Chain guides: 19-ft/lbs
Front Cover (perimeter and top center): 22-ft/lbs
Front Cover (lower center): 89-in/lbs
Trio of engine mount studs: 89-in/lbs
Old 12-06-2015, 11:08 PM   #4
JBushman
JBushman is just really niceJBushman is just really niceJBushman is just really niceJBushman is just really nice
1994 SL
Would echo the idea of pulling the motor to do it. I just did mine and I think it would be REALLY hard to try to get the cover off, get all the old gasket cleaned off and get the new cover on with that RTV on it, without smearing it all over the place and messing up the seal.
JBushman is offline   Reply With Quote
Old 12-07-2015, 04:06 AM   #5
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
I agree with fetchitfido that pulling out the engine to do the job would be the easiest way if you have a hoist and are familiar with engine removal.
However, I have removed the timing cover twice now on my SL2. The first time, I replaced the timing set. And I will agree, that the space in there is very tight. But that doesn't mean it is impossible.
First off, the two sources I used for instruction were my alldatadiy acct (referenced by billysvue) and the Haynes manual (found at my local library). Just think things through before you do them and take your time. A good metric set of tools is needed. Most fasteners require just a 3/8" drive ratchet and a variety of sockets. A small 8mm wrench is needed to removed one of the 4 bolts that hold the end of the oil pan to the timing cover. The other 3 can be removed with a small 1/4" ratchet and 8mm socket.
Probably the biggest challenge is properly cleaning the mating surfaces of the timing cover and head/block/oil pan, and then managing to apply the right amount of RTV and getting it back together without smearing it all over. To ensure ample room, REMOVE THE MOTOR MOUNT BASE. There are 7 screws total I believe, and three of them are accessed from inside the wheel base, so the plastic wheel cowling must be removed.
Here are some helpful references:
DoSumpthin video
My posts with pictures:
http://www.saturnfans.com/forums/sho...2&postcount=56
http://www.saturnfans.com/forums/sho...9&postcount=59
bachands is offline   Reply With Quote
Old 12-07-2015, 09:01 AM   #6
Highmile
Highmile's Avatar
I've done the timing chain in the car and it's really not that bad. I'd do it in the car before I pulled the engine to do just a timing chain.
Couple of things to keep in mind... don't forget the bolt in the center of the cover, take the water pump pulley off, having someone there to hand tools back and forth is a big help, plan of going from under it to on top a bunch of times, be very careful not to round any of the bolts off on the cover (use a 6pnt socket, etc
Also remember that after the timing cover is off that you will need to do the oil system prime.
The top gear does take the 3/16 drill bit for position and the lower has a mark that aligns with a mark on the block. The mark is at the 12 o'clock position or straight up.
Good Luck
Highmile
'95 SL1 588k and counting
Old 12-08-2015, 04:48 PM   #7
http://www.differentracing.com/tech_...ochtchain.html
IIRC, you won't have to pull the PS pump for the SOHC
Old 12-10-2015, 12:34 PM   #8
marko16
marko16 has a spectacular aura aboutmarko16 has a spectacular aura aboutmarko16 has a spectacular aura about
If you leave the motor in its helpful to remove the engine mount bracket. The bolts go through the wheel well. It really creates space especially when getting the timing cover back on.
marko16 is offline   Reply With Quote
How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pictures mrbios How-To Library 17 05-03-2019 01:04 AM
Step by step on replacing the entire wiring harness on a 95 SL1 SOHC Meistersinger S-Series Tech 1 08-08-2014 10:35 PM
Step-By-Step - 3.5L Throttle Body Coolant Bypass (with pictures) burnout Vue Mods 14 01-21-2010 04:12 PM
Intake Manifold Gasket replacement step-by-step hydromech S-Series Tech 1 12-11-2007 10:31 AM
Step by step on how to install a obx header with pic Gman3 S-Series Mods 22 09-14-2006 12:11 AM
