Old 06-28-2014, 10:58 AM   #1
doc111054
doc111054 is on a distinguished road
Default Rear Spring Upgrade
2003 Ion 1 ..45K (original owner)
Is it normal for this car to take bumps hard. It sounds like it's bottoming out when i just hit a normal bump. The springs do not look to be broken.
I did replace the shocks on the rear, the old one were shot which i found surprising with only 45k on the car.
Looking for a spring upgrade.. any ideas or am i just wasting my time?
Thanks for any help
doc111054 is offline   Reply With Quote
Old 06-28-2014, 02:42 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Rear Spring Upgrade
If you want to stay with oem style, fe2 replacement is a mild upgrade, and fe3 is pretty sporty. Not a waste of time at all
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 06-29-2014, 09:12 AM   #3
doc111054
Ok.. I found some Moog CC81065 variable rate springs for $30.00 a pair plus shipping. Seems kind of inexpensive for a set of springs. The question is will that take care of the banging when i hit a bump?
Old 07-01-2014, 01:04 PM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
usually if you hit bumps, and makes you car bounce for a block, it would be the shocks getting old/worn down. i had replaced mine with KYB Excel G for a cobalt, and megan springs (part of the reason changing them was to lower it), and it had stopped the bouncing almost entirely. now that it has some milage on it, the ride has smoothened out but still with little to no bounce. a good shock and spring replacement will solve any bounciness
03 ion-2 Sedan 5sp
♕KCCO
Old 07-01-2014, 03:09 PM   #5
2006 ion2
2007 ION-2 Sedan
My advice is to do all 4 corners, though, not just front or back.
2007 Saturn Ion 2
rear view mirror upgrade greenman Aura General 14 01-03-2018 10:26 AM
Vue rear view mirror upgrade Jess Lookin S-Series Mods 11 10-26-2012 10:54 PM
Rear disc brake upgrade? Deep6 L-Series Tech 2 01-10-2010 08:45 PM
97 Horn Upgrade Fiamms/Wolo Bad Boy Wiring ( Don't Burn Out Your Spring Clock ) GQROD S-Series Tech 42 07-22-2009 09:25 PM
Rear disc upgrade? tjd83 S-Series General 9 08-29-2006 05:44 AM
