#1 |
![]() Join Date: Feb 2007
2004 ION-1 Sedan
2002 L-Series 2.2L Sedan
Here is the run down.
04 Saturn Ion Series 1. 109K miles. I tried to start up my Ion this afternoon, only to realize it hesitated, and finally turned over, only then to idle roughly with the engine light blinking. I promptly turned off the car, and popped the hood. I noticed my coolant level was low, and added some coolant, and checked the oil and noticed that low (I've been a bit neglectful, I've been driving 1K a wee for work). Started up easier, but still idling rough. Thinking it may need more oil, I need to check that again since I've added some. Any recommendations, as I do not want to further damage my vehicle as to what to investigate. Thank you for any responses, I will update. |
#2 |
![]() ![]() ![]() ![]() Join Date: Nov 2007
2008 Outlook XR
2007 AURA XR
blinking check engine light means dont drive it
#3 |
2004 ION-1 Sedan
#4 |
definitely the coils, but they can take out the ICM and the plugs.
2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand. |
#5 |
![]() Join Date: Jan 2009
2005 ION-2 Quad Coupe
I just had that same problem, changed the coil and ICM, running wonderful now. I dont know which it was but I would say that sounds like your problem. You're lucky, I only got 59k outta mine.
Best of luck! |
#6 |
2004 ION-1 Sedan
Went to Murrays, but they did not have the part, so for a Sunday, no dice. But I will try again tomorrow to pick up the icm. Question is, do I need to get coils as well, and what exactly are these coils?
Any help would be appreciated. |
#7 |
Replace the control module and the plugs.
A lousy day in paradise is still a day in paradise. |
#8 |
one usually seems to take down the other, the coils are what's in the black plastic piece, they convert the voltage to the level needed for the plugs.
#9 |
Go to this thread http://www.saturnfans.com/forums/sho...d.php?t=131652 and scroll down to post#4, there is another link there also but the picture is showing the underside of the coil, provided the 04 is the same(?). Very easy to do, I only had 4 bolts holding my coil on and I think there is 3 for the ICM, just watch for the clip where the wiring harness is plugged in, there was an extra little grey clip that I had to completely remove before unplugging the ICM.
#10 |
2004 ION-1 Sedan
@ 2006 ion2: So I should pick up the coil as well?
@ elizann773: Thank you. I had seen your post and kept diving for more info. I'm hoping this takes care of the problem. I really don't want to miss a whole day of work! By the way, not that it changes any thing, but what I'm I looking to spend? TY! |
#11 |
In my area(center of no-where NH lol) the coil was $120-130 and the ICM was $80, but I also found nobody stocked the ICM....except maybe a dealer, but I didnt even bother with them since my nearest is over an hour away.
To change the unit, it took probably half an hour, not long at all. I have a general question for anyone tho...when I had the code reset it was also reading a code for my coolant being below temp. I just had to change the coolant tank/resevoir(it was leaking at the joining seam), could that have led to the latest problem or is it most likely just coincidence? Just a thought, didnt know if it might trigger anyone elses memory of a coolant issue prior...? Last edited by elizann773; 01-11-2009 at 10:00 PM. |
#12 |
yes, one usually seems to take out the other, the bad ICM would be sending the wrong/no voltage to the coil(s), frying it/them, then fouling the plug(s) there are two coils.
the coolant being below temp would point to the temp sensor being bad or a stuck open thermostat I would think
#13 |
I noticed when I had the other problem the car was taking forever to warm up when I did drive it, but its been fine since the fix. I havent had another code since so Im crossing my fingers...
Thanks |
#14 |
yeah, these engines run so cool without missing cylinders, and in a NH winter, that could have caused it, just keep an eye on it, if it recurs, suspect the thermostat.
#15 |
2004 ION-1 Sedan
Thanks for everyones help. I replaced both the coil, icm, and spark plugs to a tune of $240. Now I'm back in business, car is running great!!!
#16 |
WOO HOO!! Congrats!!
![]() Now my engine light is back on again, grrrrrrr.....gonna get that checked after work tomorrow, not flashing, staying lit, probably the coolant temp thing.... |
Bookmarks |
Rough IDLE/Low IDLE no check engine light | savage21 | Vue Tech | 9 | 12-08-2010 01:27 AM |
Service engine light blinking and rough running/loss of power to stall | bskicrash1 | S-Series General | 18 | 09-17-2007 10:16 PM |
service engine soon light, idle a bit rough | tdm850rider | S-Series General | 24 | 01-26-2006 05:14 PM |
rough idle and check engine light | t0pk0w | S-Series Tech | 3 | 01-03-2004 11:28 AM |
SES light rough idle after engine cleaning | debaser | S-Series Tech | 4 | 07-31-2002 10:19 PM |
