#1 |
![]() Join Date: Sep 2000
I picked up my 98 SL2 (88,000 miles) today from the body shop where they had replaced part of the dashboard console that was damaged in a break-in. The car is now idling very rough and the SES light flashes. When I checked under the hood, I could tell that they had cleaned my engine while it was in for repair. There seems to be a thin coat of an Amor All type oil over every thing. Of course, the body shop claims that they didn't do anything that would cause this problem and that it must be a coincidence. I haven't been able to take it to have the codes read yet. Any thoughts on what might have happened and how I can fix it?
#2 |
Check the spark plug wells for water. If they washed the engine down then they likely got water in there and the wires are arching to ground by the plugs.
#3 |
A flashing SES light is almost always an indicator of a misfiring spark plug...as ssicarman said...plug wells have water in them or there is a short between 2 or more plug wires perhaps even at the coilpacks...check them all out for moisture and wipe the oily stuff off them as well.
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#4 |
![]() Join Date: Jun 2002
If you have an Autozone in your area (I know they're pretty much all over the US), you can take your car there, and they will read the code for free, and print you out details as to what the code entails. All it takes is a few minutes.
#5 |
![]() Join Date: Mar 2000
I had the same thing happen to my SL2 after a body shop had cleaned under the hood.
Darn thing sounded like the engine was falling apart until the water baked away from engine heat. |
Bookmarks |
Rough IDLE/Low IDLE no check engine light | savage21 | Vue Tech | 9 | 12-08-2010 01:27 AM |
02 vue ses light and rough idle | gaurdien | Vue Tech | 7 | 04-26-2007 07:37 PM |
rough idle, SES light | AnotherSaturn | L-Series General | 4 | 11-07-2005 09:39 PM |
SES light (steady, then flashing), extremely rough idle | wtaylor76 | L-Series Tech | 12 | 10-07-2005 02:53 AM |
argh.. ses light / rough idle | 92saturnsl2 | S-Series Tech | 7 | 09-15-2002 03:36 AM |
