Old 06-02-2016, 07:42 PM   #1
polar12381
polar12381 is on a distinguished road
1995 SC1
Default Why is there oil on my spark plug? SC1 1995
Hello everyone new here. So I just had my 1995 Saturn SC1 rebuilt. I drove it for 300 miles and it started to jerk on me. Check the plugs and found oil on the number 4 plug. I went back to the shop that rebuilt my engine and they want me to have someone do a cylinder leak test. If so why? Should a compression test be good enough? They also want me to test the fuel injectors even though its oil on the plug not a mixture of oil and gas and it does not smell of gas. I sure could use some help with this .
Thanks
polar12381 is offline   Reply With Quote
Old 06-02-2016, 10:24 PM   #2
Default Re: Why is there oil on my spark plug? SC1 1995
If you have oil on the spark plug the odds are great that you have a valve cover leak, check for oil on the outside of the plug and boot. If none then get the rebuild shop to run a compression test. An engine that is misfiring is not a candidate for a leak down test but it is definitely in need of a compression test.
Exactly what brand and type or number of plugs are in the engine??
Old 06-02-2016, 10:42 PM   #3
polar12381
1995 SC1
Autolite plugs and Bosch wires then changed wires and plugs to NGK plugs and Ultima Select wires and still have the same problem.
Old 06-02-2016, 10:43 PM   #4
polar12381
1995 SC1
4 Plugs
Old 06-02-2016, 10:45 PM   #5
polar12381
1995 SC1
Valve cover checked no leaks
Old 06-02-2016, 10:51 PM   #6
polar12381
1995 SC1
Updated my profile also
Old 06-02-2016, 11:15 PM   #7
If you have oil on all 4 plugs try keeping the RPM at 2500-3000 max and do not drive at constant speed. I would also suggest that a compression test be run on all 4 cylinders.
Old 06-02-2016, 11:33 PM   #8
polar12381
1995 SC1
Sorry I misunderstood yes just the number 4 plug is being soiled with oil the others are fine no oil on the others.
Old 06-02-2016, 11:35 PM   #9
polar12381
1995 SC1
My mechanic will do compression test tomorrow. The rebuild shop said to test the fuel injectors. Why? Any Ideas?
Old 06-02-2016, 11:59 PM   #10
Bad injector will cause a miss as well but first check compression and then there is more. Injector testing is not a simple task as you get to swap #4 with another one so the fuel rail has to come off and that is a job that can end up creating problems.
Old 06-03-2016, 10:45 AM   #11
SC2Sick
1995 SW2
I'm not following how they're associating fuel injectors with oil on plugs.
Did they replace valve seals when they did the rebuild?
sixthsphere.com owner
2002 Saturn SC2 - RHD
Old 06-03-2016, 12:23 PM   #12
The are equating the misfire with oil pumping past new rings. They are guessing ...
Only 1 plug is fouling out. Engine has 600 miles on rebuild and #4 fouled out at 200 miles and has now done it again at 600 total. Not valve seals or failed injector.
Old 06-03-2016, 01:22 PM   #13
SC2Sick
1995 SW2
What exactly did they do that's considered a rebuild?
Old 06-03-2016, 01:35 PM   #14
That question has yet to get a detailed answer. Presently checking compression, injector resistance etc and whatever the OPs mechanic decides to check. My guess is it was a hone, re-ring, and bearings for the lower end. No idea on head. Just a hone & re-ring would explain oil in #4 only.
Old 06-04-2016, 04:44 AM   #15
Murphys_ghosy
Murphys_ghosy has a spectacular aura aboutMurphys_ghosy has a spectacular aura aboutMurphys_ghosy has a spectacular aura about
Murphys_ghosy's Avatar
1998 SW2
Stories like this are why I learned to work on cars. My first SL1, a blackberry 99, was my Uncle Ben. Killed by a 5-Minute-Oil-Change and some other guy who was also a moron.
Time for rebuild #2 before your Saturn goes Apollo I.
98 SW2 - 184k
04 Bonneville SE - 249k
94 Ranger XLT - *rebuilding currently*
RIP (well loved organ donors)
99 SL1 - 167k
99 SL1 - 300k
Murphys_ghosy is offline   Reply With Quote
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 08:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-20-2011 12:52 AM
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-15-2009 12:31 AM
Newbie-Spark plug change 1995 SL1 jdk S-Series Tech 10 06-23-2008 12:02 PM
1995 SW2 spark plug wire order and torque? 95 staturn Mods and Performance 1 04-18-2005 08:29 AM
