Old 11-14-2016, 04:31 AM   #1
polar12381
polar12381 is on a distinguished road
1995 SC1
Default 1995 Saturn SC1 Over Heating
I have a 1995 Saturn SC1 and it is over heating. I have replaced water pump, thermostat,coolant temp sensor,temp sender and it still overheats. The radiator fan is working. I do not know what else to do. Please help.
polar12381 is offline   Reply With Quote
Old 11-14-2016, 08:57 AM   #2
Default Re: 1995 Saturn SC1 Over Heating
Pressure cap? They are cheap at the autoparts store.
Presumably by overheating, you have loss of coolant, and not just a gage reading in the red zone?
Or, have you checked to see if a steady stream of coolant is returning to the reservoir by looking at the small 'window' or cutout in the plastic reservoir?
Blockage would cause a major overheat situation.
Old 11-14-2016, 09:25 AM   #3
Highmile
Highmile's Avatar
Showing signs of a blown head gasket?
Could just be that it needs a new radiator, more so if it has never been replaced.
More details of when it gets hot, how long it runs before it does, etc might help
Highmile
'95 SL1 616k and counting
Old 11-14-2016, 09:04 PM   #4
Saturn Night
Check the line going into your expansion tank. If it is not a steady stream flowing continuously, you have likely cracked your cylinder head of head gasket.
Before throwing money at the car, run test it with the cap off. If it heats up and bubbles are continuously in the coolant, you have an expensive repair ahead of you.
Run a leakdown test as well as a compression test.
A similar thread ended badly for another user, on his 2nd Gen SOHC, which was a blown head gasket.
1995 sl2 close to over heating freedominco S-Series Tech 4 12-05-2014 06:42 AM
Very Wierd Heating issue SW2 1995 DOHC Darkone S-Series Tech 7 11-14-2014 12:25 PM
1995 SL2 Over Heating bcbradford S-Series Tech 3 06-13-2011 03:08 PM
1995 Saturn SL2 Start Porblems- I NEED A SATURN EXPERT! JamesDator S-Series Tech 33 10-30-2007 05:11 PM
1995 SL2 Over-Heating Saturnrace S-Series Tech 10 10-03-2006 10:44 AM
