Old 09-21-2006, 02:10 AM   #1
The Critic
The Critic is on a distinguished road
The Critic's Avatar
Default Transmission leak, common places?
http://www.saturnfans.com/forums/sho...13&postcount=2
True?
Mine is dripping down the side of the case, could be from the top?
Any suggestions?
The Critic is offline   Reply With Quote
Old 09-21-2006, 02:56 AM   #2
wolfman
wolfman's Avatar
Default Re: Transmission leak, common places?
In order of frequency:
1. Filter (especially if fluid was just changed)
2. TTS (Transaxle Fluid Temperature Sensor) Especially if the fluid was just changed as it is right next to the filter.
3. Axle shaft seals (usually just minor drips)
4. Top "pan" (cover) gasket. (Seen usually as runs/drips down the case.
5. Cooler lines at radiator
6. TSS or VSS (Turbine speed sensor) (Vehicle speed sensor)
7. Torque convertor/input shaft seal (seen as drips at lower inspection cover)
Old 09-21-2006, 03:00 AM   #3
The Critic
The Critic's Avatar
Thanks.
Currently have 93,800, leak has been there since a little under 50,000 miles. Filter was last done at 34,000 miles, yes, will be doing it in the next few weeks.
I think I can eliminate #5, I've checked those already.
Has anyone tackled a top cover gasket job before? How difficult? How time consuming?
Thanks.
Old 09-21-2006, 03:09 AM   #4
wolfman
wolfman's Avatar
If you do not have ABS, it is not too bad. If you do, it is a bit more of a pain but still a DIY job. (No special tools needed)
Old 09-21-2006, 03:14 AM   #5
The Critic
The Critic's Avatar
Hmm, I do have ABS on my SL2 unfortunately.
How would I "support" the master cylinder and ABS module while taking off the top cover? One member here has suggested bungee cords.
Supposedly I've been told that this can be done around an hour? How long has it taken you, Wolfman, (or anyone) to do this job?
Old 09-21-2006, 03:21 AM   #6
wolfman
wolfman's Avatar
Without ABS it takes about an hour.
With ABS add another 30 minutes of so.
Bungee cords (heavy duty...no cheapees) will work to support the ABS mastercylinder. (Coathangers bent creatively will too) BE CAREFULL when moviing it out of the way not to be overly and quickly violent as you can snap or pinch one of the metal brake lines. When moving the AC, think of the coiled metal brake lines as a spring you are stretching and then when you are putting it back, as springs you are compressing, and move the MC accordingly.
Old 09-21-2006, 04:06 AM   #7
bobbyrae
bobbyrae has a spectacular aura aboutbobbyrae has a spectacular aura about
1993 SL2
When I bought my car, it appeared to have a slight transimission fluid leak, and the receipts indicated that the mechanic had previously tried to fix a tranny leak by replacing the filter. Since there still was a leak, I was dubious if that was the problem.
And when I replaced the filter, it appeared that there was STILL a leak! However, checking around under there indicated that the filter was the likely source, so I used the filter wrench to tighten it a bit beyond that "hand tight" point they recommend, and the leak stopped!
I hope it's that simple for you.
Bobby Rae
Alameda, CA
1993 SL2 A/T, 80k miles, 22/33/43 mpg
1982 Accord 5-speed, 303k miles, 23/32/40 mpg
bobbyrae is offline   Reply With Quote
Common places for oil leaks on V6 pupilot007 L-Series Tech 4 12-16-2009 09:02 AM
common AC leak areas to check 425oldsmar S-Series General 4 08-12-2009 09:28 AM
Driver side leak & sunroof leak-common? Miss Holly S-Series Tech 3 01-06-2008 02:01 AM
Radiator leak - is this common? Gbody403 S-Series Tech 12 03-15-2007 10:03 AM
common oil leak? BigMac Miscellaneous Tech 6 02-03-2004 09:00 AM
