Old 07-17-2006, 07:39 PM   #1
DanB98TJ
DanB98TJ is on a distinguished road
1997 SW1
Default Rear hatch electric lock motor
I was messing around with the tailgate of my SW1 to figure out why it wouldn't unlock with the remote or interior handle. Turns out the gear inside the actuator is stripped - not a surprise after seeing how small it is.
Anyone know if the actuator is the same as the lock motor for the doors? I haven't been able to track down a separate listing for the rear hatch on any of the online parts catalogs, just the right and left door lock actuators. It's not a big deal if it's not working, but if it's not too expensive I'd like to replace it.
1997 Saturn SW1, auto trans, 121k miles
DanB98TJ is offline   Reply With Quote
Old 07-17-2006, 09:11 PM   #2
Default Re: Rear hatch electric lock motor
Is it the same latch as the trunks on the SC's?
My SC1 had the same type of problem and I fixed it by switching the latch from my SC2 to it, and I gave it some WD-40 for good measure.
You might be able to get it from a junkyard.
Old 07-18-2006, 12:54 AM   #3
DanB98TJ
1997 SW1
Not sure if it's the same latch as on the SCs - this is my first Saturn so I'm not familiar with how the parts interchange between models. Maybe if I get ambitious I'll pull one of the door panels and see if it's the same...but that'll have to wait until the temps drop to under 100*.
Old 07-18-2006, 03:35 AM   #4
I thought the in-car release on the sedans/coupes was mechanical.
Old 07-19-2006, 12:52 AM   #5
DanB98TJ
1997 SW1
Not sure about the coupes and sedans, but the in-car "handle" near the seat in the wagon is a switch....
Old 07-19-2006, 02:29 AM   #6
Yeah, I know; that's why I was asking specifically about the SCs/SLs. Makes sense it's a switch; if it were a cable, it'd have to go thru the tailgate.
Old 07-19-2006, 06:31 AM   #7
In my SC's the in car trunk release lever works like a switch, the hood release has a cable.
If the latch is setup the same way in the wagons as it is in the SC/SL then it's really simple to remove, with just 2 10mm(I think) bolts holding it on and 2 rods that connect it to the key lock cylander.
2003 Vue-back hatch won't lock? vueowner03 Vue Tech 3 02-22-2008 11:40 PM
Rear Hatch Jeffro36 Vue General 4 01-09-2008 10:10 AM
Sticking rear hatch lock zaphod4239 Vue Tech 0 03-06-2007 10:56 PM
Rear hatch won't lock. bk63 Vue General 3 03-29-2004 02:34 AM
Sticky lock in Vue rear hatch mr weather Vue Tech 2 10-24-2002 01:27 PM
