#1 |
![]() Join Date: Jun 2004
Hello,
I am looking to change my transmission fluid. I have seen these "power flushes" that the local "sheisters", aka auto transmission repair shops, offer for about $100 that suck all the old fluid out. This seems like a good idea, but not at that price! Can I disconnect the transmisoon cooler tube from the radiator and drain that into something with the car running in D? Can I drain out all the fluid and then shut the car off to fill w/o damaging anything? If not, what is the best way to change it? Will using the drain plug and changing the filter be enough to flush out the old fluid? Thanks! |
#2 |
![]() Join Date: May 2002
It has worked for me......simply regularly changing....
> 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired |
#3 |
You are fortunate to have a drain plug and easily reachable/changeable filter. Most other cars don't and have a pan that makes a royal mess when dropped and needs resealing every time. The cooler flush people invented this gadget for those cars.
Luke is right; service it the way saturn intended. Doing it a few times in quick succession (fluid is cheap) will essentially dilute the original fluid to nil. This is overkill... but a good kind. ![]() |
#4 |
I've read on here that the trans holds about 7 quarts of fluid, and you usually change about 5 quarts when draining the fluid and replacing the filter. So you leave about 28% of the original fluid.
If you changed it again, you would then have approx 8% original. A 3rd time would leave about 2% of the original fluid. Unless there was a reason for great concern about the fluid, I would change it like normal and wouldn't worry about it until the next 30k miles go by. |
#5 | |
![]() Quote:
#6 |
The "S" series transaxle was designed NOT to require "flushing" Hence the external filter, magnet(s) etc... DO NOT pay for this "service" a drain, filter change and refill (at the scheduled intervals in the maintenacne schedule) are all that is needed or required.
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#7 |
![]() ![]() ![]() ![]() Join Date: Apr 2000
2007 ION-2 Quad Coupe
1997 SC1
Luke & Wolf have it spot on as usual.
I recommend the factory filter as it takes a lot more pressure than an engine one and some of the aftermarkets aren't as stout in the can thickness. |
#8 |
ok this topic seems less controversial than my brake bleeding one. thanks for the replies. i will do it the easy way.
thanks! |
#9 | |
![]() Quote:
BOTTOM LINE: change the fluid and filter every 30K, or less. then you have nothing to worry about. |
#10 | |
![]() Quote:
I am also into overkill. Since my car was a little abused and late on maintenance, I am changing fluid early. I read something by ssicarman about doing several quick fluid changes to get more of the old fluid out of the system. That is for a neglected system, and you would only change the filter one time. But, if you or the previous owner was good on maintenance, changing the fluid and filter at least every 30,000 is recommended.
Truth alone triumphs, not untruth. |
#11 |
Yep, just read owners manual and Alldata again. Looks like I have a little too much fluid in there (above hot full mark). Oh well, I bought some plastic hose to suck some out of the filler tube. Alldata has a nifty picture of a dipstick. Says the ideal operating range when hot is right at the top of the cross hatched area. Think I will shoot for that this time. Good luck!
#12 |
Oh, I did not need to add as much fluid as you will. This time I did not change the filter, just drained fluid and filled. Not due for the filter yet. You will probably need to add more fluid to get it to the appropriate level.
#13 | ||
![]() Quote:
Bookmarks |
Trans fluid change 3.5L Auto | djhhjd | Vue General | 5 | 11-04-2009 10:02 AM |
99SL2, Auto, 170k - Plugs, Trans fluid, change? | jimsz | S-Series Tech | 6 | 09-15-2006 11:50 PM |
Auto Trans Fluid? Which one? `02 SL2 | cdb95lt1 | S-Series General | 1 | 02-04-2006 02:00 AM |
3.5 auto trans fluid change warning!! | David Harleyson | Vue General | 10 | 08-15-2005 08:51 AM |
SL1 AUTO TRANS FLUID CHANGE? | satrunracer | S-Series Tech | 3 | 06-20-2001 02:19 PM |
