#1 |
![]() Join Date: Jun 2003
I have oil leaking from somewhere behind the cam cover (between it and the firewall), below the oil filler cap -- but it doesn't seem to be coming from the cap. There are wires back there that are all oily; are they for injectors or sensors? Any ideas on what might be leaking back there? Thanks.
#2 |
![]() Join Date: Jun 2002
Valve Cover Gasket?
85 GLH 367whp. http://www.saturnfans.com/forums/showthread.php?p=2261629#post2261629 00 Insight 72mpg |
#3 |
it could be the cam cover seal is leaking.
eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe |
#4 |
Finally got a chance to inspect it today, and I'm amazed at what I saw. The cam cover is pushed out and split open (maybe 3/8") on the end near the PCV valve. I have no idea what could've caused that -- does anyone else? The engine is running fine, BTW.
I guess (hope!) that's not a common occurrence. Bizarre... |
#5 |
Sounds like it either has been replaced at some point improperly or an overpressurization has occured. Ever replace the PCV valve in that car?
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#6 |
![]() Join Date: Sep 2002
Does'nt that cam cover run about $340 or so at the friendly retailers part desk?
#7 |
BigMac: If you actually mean the cover is damaged, and not just the gasket, I have a replacement cover which I believe is for your year. I picked it up in error, and will part with for few $.
Bookmarks |
common AC leak areas to check | 425oldsmar | S-Series General | 4 | 08-12-2009 09:28 AM |
2003 VUE V6 oil leak - common? | bxd20 | Vue Tech | 3 | 06-02-2009 09:18 PM |
Driver side leak & sunroof leak-common? | Miss Holly | S-Series Tech | 3 | 01-06-2008 02:01 AM |
Radiator leak - is this common? | Gbody403 | S-Series Tech | 12 | 03-15-2007 10:03 AM |
Transmission leak, common places? | The Critic | S-Series Tech | 6 | 09-21-2006 04:06 AM |
