#1 |
![]() Join Date: Sep 2002
I have the EGR with the black stack and the wired connector.I got an annoying chuggle/bottoming out at about 2500-2800 rpm under light throttle at times.VERY annoying.Never sets off SES though.I've put in new Saturn Genuine plugs and wires+Fuel filter,still has the problem after.
Can carbon be built up in there after 55k? How do I clean this thing and the orifice it goes into? If this don't do it,next stop TPS! ![]() |
#2 |
![]() Join Date: Jan 2001
use the 'search' function here, and you'll find plenty of descriptions. Generally, it's "use carb cleaner and a stiff brush" and "clean the mounting hole too." Chilton guide says to use piano wire to clean the mounting hole, but I can't even picture that. Good luck, if it works, you save about $100 on the cost of a new EGR.
#3 |
Are these electronic EGRs prone to fail?You make it sound like the best fix is to replace it,is this true,or can these valves be cleaned periodicly?
#4 |
The linear electronic EGR valve used on 95' and above Saturns uses an electric "step motor" to open and close the EGR valve's pintle more precisely than the old vacuum operated valve. The LOWER portion of the valve has a visable shaft which can be cleaned if gummed up with deposits. The engine passage itself can be also. For the valve, CAREFUL application of a spray carb cleaner and an old toothbrush. Same goes for the engine passages, although a brass brush can be used to clean the engine aluminum.
Old Saturns never die, people KILL them, so check your damn oil! "Unthinking respect for authority is the greatest enemy of truth." Albert Einstein |
#5 |
Wolf,can I vacuum out any loose carbon dust from the manifold after I scratch it off?
Also,does this sound like my problem,stumble on light accel at 2500-2800 RPM? ![]() |
#6 |
Vacuum not really necessary but feel free. A stumble at 25-2800 rpm "could" very well be EGR related as that is the rpm range where maximum EGR function comes into play. General tune up items (plugs/wires/fuel injector cleaning) are also things to investigate.
#7 |
I did the plugs/wires/Fuel filter thing already.All genuine saturn goods too.
If the EGR is the culprit great,if not,TPS,here I come! I also have the brown coolant temp sensor in my saturn parts goodie bag,just in case ![]() |
#8 | |
![]() Join Date: May 2002
Fm Wolf:
> 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired |
#9 |
I NEVER get a light!Is'nt that weird???
#10 |
my car was doing the exact same thing as you. I thought it was the spark plugs and when I slapped on the BOSCH, the only diff. I felt from them was NO MORE CHUGGING!
-96 SC2 gets 35 mpg mix city/hw. |
#11 |
I'm led to believe a different brand of plugs won't produce any better results than the Dealer bought NGKs I just installed.
I'm going to focus on the EGR next.... ![]() |
#12 | |
Mike:
#13 |
I thought any disruption in normal operation would trigger a SES code/light.How can the problem sneak by daily with out triggering the light?
The light works when I put the car in start,so it's not burn out... |
#14 |
Just my 2 cents, when mine went out, I couldn't even keep the car running -- once it was in gear, it would stall. No SES light, just stalling.
#15 |
Jason,you have OBDII right?Do you have the Linear electronic EGR valve in yours?
#16 |
In answer to the question "how can the valve have a problem without the ses light coming on?" The PCM (OBD2) monitors the POSITON of the EGR valve's pintle in relation to where it "should be" based on the signal being sent to and FROM the EGR valve. The valve itself can be working just fine BUT if some crud is preventing the pintle from sealing OR enough crud has built up to prevent proper regulated flow when the valve operates, it CAN affect operation without the PCM "seeing" anything "wrong" with EGR function. Just as in the older (PRE 95') cars with the vacuum operated valves, the PCM could only "see" problems with the electrical circuit of the EGR. A bad EGR valve in those cars actually RARELY set an SES light.
#17 |
Thanks Wolf!I'm going to see what I can do with that valve.Do I need use new gasket and hardware after cleaning?
#18 | |
Be kind to me all......for I may bereally off on this, but here goes...
#19 |
Hmmmmmmmm...How many EGR valves have you gone through?
#20 |
Auxmike,
Provided the EGR valve gasket comes off in relatively good shape, you CAN reuse it. Rip or gouge it enough to cause a leak BETWEEN the ports or to the outside air and you'll need a new gasket. ( times out of 10 the gasket CAN be reused)
Bookmarks |
how do you clean a egr valve | saturncrzy | S-Series General | 10 | 05-16-2008 07:36 AM |
EGR Valve Clean Screen | acman | S-Series Tech | 3 | 01-22-2008 12:03 PM |
Best way to clean an EGR valve | oseberg | S-Series Tech | 4 | 08-31-2007 10:40 AM |
How long to tell if EGR valve clean worked | 07green1 | S-Series General | 2 | 04-05-2005 04:34 PM |
P1404 - EGR Valve is clean | ddpphx | S-Series General | 4 | 09-03-2004 02:10 AM |
