Old 08-05-2009, 06:23 PM   #1
Breezepimp98
Breezepimp98 is on a distinguished road
Breezepimp98's Avatar
Wrench Average Oil Use?
I have a 1998 Saturn SL2 with over 100k miles...
My question is what should the average oil use be?
I know they are known to use oil, Just curious as to how much.
I have put 1600 miles on mine since i bought it and have had to put in 2+ Qts..
If this is too much what would my problem be?
Thanks in advance,
Dale
Breezepimp98 is offline   Reply With Quote
Old 08-05-2009, 06:58 PM   #2
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
1994 SL2
Default Re: Average Oil Use?
people use different amounts of oil depending on their car
I've read of people using a quart every 100 miles, BAD
to not needing any at all
On mine 98 SL2 (104k) I run about every 450 miles
On dad's 98 SL1 (260k) about every 1500 miles
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Saturninin is offline   Reply With Quote
Old 08-05-2009, 07:32 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Wife's SC1 uses about a quart every 2 tanks of gas, mine used to use about the same, but it has a fresh engine now that seems to use none. It all has to do with the condition of the engine. When reach the point that you literally have to fill the oil and check the gas (can't go between fillups without topping off the oil), that's when you should really worry, IMO. Until then, it's within a pretty normal range for an S-Series with some age & miles on it. Really it's up to you & how inconvenient it is for you. Be sure to check for leaks.
SaturnSeries.net owner
Old 08-05-2009, 07:54 PM   #4
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Most manufacturers would say your vehicle has acceptable oil usage if it goes 800-1000 per quart of oil.
MiSaturn is offline   Reply With Quote
Old 08-05-2009, 07:59 PM   #5
Tiger
Tiger is a jewel in the roughTiger is a jewel in the roughTiger is a jewel in the rough
Tiger's Avatar
I am using around 1 quart per 750 miles. I am at 152,000 miles. Highway trips basically double the amount I use. I would say what you are experiencing is normal. The ring and piston design tends to be the problem. You may want to try a MMO soak (piston soak with Marvel Mystery Oil) to see if it can free up dirty oil control rings. The How-To Library has details. Luke took his 95 SL2 over 500,000 miles. He was using about 1 quart per 200 miles by then. So, your car can go a long time just adding and changing the oil. A common area that leaks is the cam cover gasket.
Truth alone triumphs, not untruth.
Tiger is offline   Reply With Quote
Old 08-05-2009, 09:11 PM   #6
Breezepimp98
Thanks alot, I was just curious as to "average" so i should be good for a bit then..
Thanks again.
Old 08-05-2009, 10:17 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
Thanks in advance,
Dale
Saturn considers 1 quart of oil consumed in 2000 miles as "normal".
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 08-06-2009, 12:14 AM   #8
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
That is probably about where my SL2 is.. that's nothing in my opinion.. (cost, hassle-wise)
I top it up more regularly though, as in, I don't wait to add a qt, I keep it at the full line. (not more)
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
SLCraig is offline   Reply With Quote
Old 08-06-2009, 01:11 AM   #9
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
about 1 qt every 1500-2000 (i check it about every 250 though)
much better using Valvoline Maxlife Full Syn than anything else i've used (went down from about 1 qt every 500)
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
dorisSL is offline   Reply With Quote
Old 08-06-2009, 01:42 AM   #10
reggie4828
reggie4828 is on a distinguished road
reggie4828's Avatar
2000 SL1
I also use Valvoline Maxlife Full Syn and burn half a quart every 4000 on my 2001 sl-1 104.000 miles.
reggie4828 is offline   Reply With Quote
Old 08-06-2009, 08:50 AM   #11
DonP
While under warranty a quart every 2000 miles is within spec.
Mine used minimal oil (within spec) until it passed around 75K miles, then consumption started to increase noticeably.
At the moment (a bit over 150K miles, it uses perhaps a quart every 600 miles or so, but that varies with the type of driving. A lot of time near/over 3000 RPM can increase oil consumption dramatically.
Things believed to lead to increased oil consumption:
A history of extended oil change intervals (i.e., driving with dirty oil)
Driving while low on oil (reduces life of oil and additives)
High RPM driving
extensive use of engine braking (high vacuum sucks oil past valve guides???)
Things that might help, or at least prevent further increases include:
Frequent oil changes (no more than 3000 miles)
Piston soak (MMO. GM Top Engine cleaner, etc.)
A couple AutoRx treatment cycles
Switch to 10W-30 oil
Use a good synthetic oil from day one.
Avoid high RPM and engine braking
Fix any oil leaks (e.g., drain plug, cam cover, etc.)
Except for the 10W-30, engine braking, and limiting RPM, the above are oriented to cleaning the oil control rings.
Note that by and large, adding oil is cheaper than an engine overhaul so run your numbers and make you decision.
Note over time, really excessive oil consumption may reduce the life of the CATCON and O2 sensor, but I do not know what that threshold is.
Old 08-06-2009, 10:51 AM   #12
OnDaGround
OnDaGround has a spectacular aura aboutOnDaGround has a spectacular aura about
OnDaGround's Avatar
1993 SC2
You mean: unheard of... I'm down to a quart every 200 miles or less. lol
Saturnless...
OnDaGround is offline   Reply With Quote
Old 08-06-2009, 11:06 AM   #13
westwind999
westwind999 will become famous soon enough
1999 SW1
I usually don't need to add any between changes on mine. It might go down about a pint in 5,000km/3,000 miles. I've been using Auto-rx to keep it clean.
westwind999 is offline   Reply With Quote
Old 08-06-2009, 11:28 AM   #14
OnDaGround
OnDaGround's Avatar
1993 SC2
I'll trade you cars.
Saturnless...
Old 08-06-2009, 09:40 PM   #15
bygblok
bygblok is on a distinguished road
my 99 SW2 is at 204k and see's 230 miles a day right now, most at 80+mph. Last check was around a quart every 2500 or so. It's usually close to an oil change before I put any in. It's actually gotten better in the last 50k....... I haven't quite figured THAT out but I won't complain!! I'm so hapy with my Saturns over the years that I just put my son in an 02 SC2 and am building my own 02 SL2 to replace the wagon when it's time to put it down. I run well over 50k a year on my cars....HARD interstate miles too!
bygblok is offline   Reply With Quote
Old 08-06-2009, 11:44 PM   #16
geartooth94
geartooth94 will become famous soon enough
geartooth94's Avatar
the girlfriend's '95 SC2 does a quart every 225 miles. sometimes it's down to a quart every 150 miles if it's all city driving.
i just get the cheapest oil possible since it's not in there long.
1996 Dodge Avenger ES: 2.5L V6
geartooth94 is offline   Reply With Quote
Old 08-07-2009, 12:02 AM   #17
sl1driver
sl1driver is on a distinguished road
2000 SL1
I know the piston design inherently lends itself to oil usage. I guess I'm one of the lucky ones. I don't usually have to add anything between oil changes (about 5000 miles).
Andy
2000 SL1 5 speed - 149k and still going strong. Slight oil usage.
New Intake Manifold Gasket, Clutch, Ects, Thermostat, IAC, TPS
sl1driver is offline   Reply With Quote
Old 08-07-2009, 12:22 AM   #18
westwind999
1999 SW1
I hope you're not buying the oil that's SB rated that some stores sell for cheap. API SB oil will ruin your motor, you should have a modern API rating of at least SJ.
Old 08-07-2009, 12:36 AM   #19
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
Hmm, that's strange. I am always afraid to run my car over 3K RPM while shifting or driving on the freeway because I have heard that they burn much more oil this way. I am also taking it easy because my car has an unknown maintenance history with almost 180K miles and it will smoke a little bit if I rev it and let off the accelerator (worn valve seals)
So far I have driven 130 miles and the oil level hasn't moved but my gas gauge sure has I put in 6 gallons when it was on the yellow mark for "E" and the gauge went to a hair under 3/4 now with my trip meter reading 130 miles the gauge is just under 1/4 but I am going to wait until it is almost on "E" again (gas went way up here anyways )
Former DD: 1994 SC2 5spd. 190K, being sold to a friend
2005 Saturn ION 2 5spd. 73K
1995 Aquamarine SL2
1.9L DOHC 5spd. ~125K Miles
Col.FUBAR is offline   Reply With Quote
Old 08-07-2009, 12:40 AM   #20
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
What I had 10 S-Cars and not a one needed oil added between the 7,000 mile MOBIL-1 oil changes. I must have been doing something wrong.
SaturnSdn is offline   Reply With Quote
Average Consump. marx404 Astra General 2 11-21-2008 09:07 PM
Average Shipping From SaturnAccessories.com? washamur Vue General 2 06-27-2006 03:09 PM
On Average, How Often Do You Change Your Saturn's Oil? Charlie Polls and Questions 46 03-01-2004 07:42 PM
Oil consumption - what's the "average"? SpaceFrame S-Series Tech 21 01-16-2003 11:03 PM
Question about Average and Above Average ET's for Saturns. EVOscottie Mods and Performance 7 04-02-2002 10:08 AM
