#1 |
![]() Join Date: Apr 2007
Hey all,
I just got done cleaning my EGR Valve on my 94 SL2 DOHC. I tried starting the engine with the EGR valve off (it is the vacuum type, btw) and it blew a lot of crap and what looked like liquid out of the holes (I may have gotten a bit of carb cleaner in there, but it wasn't *that* much). Then there was a sound like a back fire, so I instantly let off of the starter. I have since been unable to get the engine to turn over, with or without the EGR Valve. No codes either. Even tried letting it 'air out'. Any one have some ideas? It will crank and crank and crank, then occasionally feel like it is about to start. -Will
-Will 1994 Saturn SL2 1.9L DOHC 5-speed bone-stock 1996 Ford T-bird 4.6L V8 Auto-OverDrive - Not stock - For Sale! 1989 Chrysler Lebaron 2.5L T1 - Sorely Missed |
#2 |
Perhaps you should have covered the hole.
Saturnless... |
#3 |
Oh now you broke it!?
![]() ![]() The egr valve didn't break anything as much as it was coincidence when the boom announced something went wrong. Cranking and no engine firing up may be the classic crank position sensor (CPS) failure. A spark test is needed. Remove the coil wires, noting the firing order, and have someone crank the engine over while you look for sparks across the coils. No spark means the cps just died. Replace it from any auto store stocking it. Its behind and above the starter and mounted with one 10mm bolt. The other failure, sometimes, is the ignition module where the two ignition coils mount onto.
VCX NANO |
#4 |
Will test that tomorrow AM (the spark test that is).
As for what brought me to this point, and correct my thinking if it is wrong, but it looks like a bad PCV valve with too much blow by, because when I pulled the plugs earlier, they were fouled in a very bad way (like chunkies of oil between the elements). That helped foul up the EGR valve, and is possible it could foul up the O2 sensor as well (I am not going on symptoms here, rather trying to use logic). Thanks guys'n'gals, I'll check the spark tomorrow AM when I replace the spark plugs.
#5 |
You also need to replace the ECTS with the two wire connector with a brass one. This will also cause a no start situation.
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place |
#6 | |
![]() Quote:
-Will
Bookmarks |
Which EGR passageway should I clean? | mlambert77 | S-Series General | 2 | 08-07-2009 04:06 PM |
how do you clean a egr valve | saturncrzy | S-Series General | 10 | 05-16-2008 07:36 AM |
Would it be better to just put a new EGR on, or just clean the old EGR? | Token | S-Series General | 12 | 01-18-2006 01:24 AM |
Necessary to clean EGR? | denclar | S-Series General | 18 | 11-08-2004 12:25 PM |
How do I clean the EGR valve?>>> | auxmike | S-Series Tech | 23 | 01-18-2003 12:20 PM |
