Thread Tools | Display Modes |
![]() ![]() Join Date: May 2013
2002 VUE 2.2L
As the title says, I'm replacing the rear shock absorbers in my 2002 2.2L Vue w/ 195k miles. I bought the vehicle in 2008 with 105k miles, and last weekend replaced several front-end suspension components (struts, mounts, LCA, ball joints & links) and found everything was still original factory parts.
Assuming the same to be true for the rear, are there any other components I should consider/be replacing with the shocks? I can't say I notice anything specifically "off" with the rear suspensions though either, other than after replacing the front components I can feel how bad the back needs it too now. So ideally I'd just like to order and install everything in one shot. |
![]() ![]() ![]() Join Date: Aug 2012
swaybar bushings and endlinks
'05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows. |
2002 VUE 2.2L
I was definitely think the end links myself. I noticed in another thread this morning that Saturn changed the size of the front swaybar bushings. Do you know if the same is true for the rear? Or should I just buy new clamps anyway?
![]() Join Date: Dec 2007
2002 VUE 2.2L
I had no problem replacing the rear sway bar bushings using factory parts. The rear links are actually plastic (
#5 | |
CLamps? YOu mean the bracket that surrounds the bushing? COmes with, if buying aftermarket poly bushings( Energy SUspension, Prothane, Poly Perfromance).
![]() Join Date: Jan 2005
2004 VUE 3.5L
When I did mine both rear springs were broken at the bottom at a few inches from the end. Appears to be from corrosion. I had no idea until I changed them out, so it didn't affect much. I used aftermarket springs and the alignment need serious work afterwards (including a few days to settle in). I also had one sway bar link broken.
#7 | |
2002 VUE 2.2L
One other question: Do the rear springs also need to be compressed to change out the shocks? The rear setup looks a bit different, but I'm assuming it's the same. |
#8 |
![]() Join Date: Jul 2012
2004 VUE 3.5L
Just a FYI, the parts shop i go to that gives me parts at cost, they said there are 4 different diameters to the sway bar to get the correct bushings.
Napa said there was only 1. I suggest you measure. |
Suspension components and randomness? | Taipans | Vue Tech | 2 | 02-16-2009 06:23 PM |
Replacing rear shocks on a SW2 | fatcat | S-Series Tech | 12 | 03-18-2007 08:42 PM |
Clunk on Rear Suspension - Replace with Softer Spring? | TerrazaMan | Relay Tech | 0 | 03-30-2006 11:36 PM |
Replacing rear shocks | jw38 | S-Series Tech | 15 | 01-09-2006 10:26 PM |
Which suspension components? | lilcraigford | Mods and Performance | 5 | 07-19-2005 09:49 AM |
