My 96 SC2 will often idle at around 1500RPM after its been running a bit. I've done a cursory soapy water check around the TB, EGR, and the top of the intake manifold but not found the leak. Any ideas of areas that commonly cause this issue (since some are hard to get to
![]() Fortunately this won't affect my SMOG inspection because if I shut the car off and restart it; it returns to normal idle everytime. -Robert |
#2 | |
![]() ![]() ![]() Join Date: Apr 2009
97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat |
Replace the throttle position sensor. OEM seems to be the chosen one for reliability.
VCX NANO |
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2011
2002 SC1
My TPS failure led to an idle of 1500-1700 RPM consistently. Granted, mine is an 02 SOHC. Nonetheless, the fact that on restart your car idles correctly points to the TPS.
#7 | |
The iacv is a slave unit with no feedback that's commanded to move a valve to adjust idle speed air flow. With two motors, any one that fails keeps the idle speed semi-permanent, stuck. Very few fail.
VCX NANO |
#8 |
![]() ![]() Join Date: Mar 2010
Two ways to test the TPS: with an analyzer tool that allows for data viewing, watch the TPS reading as you drive. Every time you release the throttle, the reading should fall back to 0. If it lingers above 0 by any amount, then the TPS is worn or otherwise damaged.
Another test is to connect a mechanical ohmmeter to one end terminal and the center terminal. Slowly operate the throttle through its range of motion. The resistance should change evenly, and the ohmmeter's needle should start and stop in exactly the same place every time (provided that the ohmmeter's movement is in good condition). Any jumping around or not stopping in the same place is a sign of wear and improper operation. Move the meter wire from one outside terminal to the other and repeat the operation. Works best with insulated alligator clips. A TPS is a potentiometer, or variable resistor. It works just like the mechanical volume control in a radio. Resistance material is applied in a semi-circle (and may contain varying resistance change curves (mathematical) depending on the use), and each end is connected to one of the outside terminals of the control. A sprung wiper connects to the center terminal, and wipes over this resistance material. If the resistance material is dirty or worn, rough changes in resistance will occur. If it is worn away completely, there will be an open circuit at that point. This condition as heard on a radio shows up as a 'scratchy' volume control. Sometimes a volume control or TPS can be salvaged by spraying WD-40 inside. However, concerning radio and television, this can cause trouble with some high impedance circuits, where impedances are over 1Megohm. |
#9 | |
![]() I'm still not following the logic though in how the TPS affects the actual idle. The only way the PCM can modify the idle is by moving the IAC, correct? (at least in our older mechanical TB's). So why would the PCM move the IAC in response to a signal from the TPS? Does it believe the TPS is below a "stall" position??? -Robert |
Common Trunk Leak Problem? | ngrome | S-Series General | 3 | 01-22-2011 04:29 PM |
2003 VUE V6 oil leak - common? | bxd20 | Vue Tech | 3 | 06-02-2009 09:18 PM |
Driver side leak & sunroof leak-common? | Miss Holly | S-Series Tech | 3 | 01-06-2008 02:01 AM |
Radiator leak - is this common? | Gbody403 | S-Series Tech | 12 | 03-15-2007 10:03 AM |
common oil leak? | BigMac | Miscellaneous Tech | 6 | 02-03-2004 09:00 AM |
