Old 11-24-2021, 07:11 PM   #1
Nigey
Nigey is a glorious beacon of lightNigey is a glorious beacon of lightNigey is a glorious beacon of lightNigey is a glorious beacon of lightNigey is a glorious beacon of lightNigey is a glorious beacon of light
2007 AURA XE
Default Jumper cables on a 2002 sl2 Saturn battery.... stupid question?
Well for the first time in my life I somehow left my lights on and was faced with a dead battery the other day. No problem I thought, I'll just use my car jump starter I have handy....
Alas, I had huge issues trying to do this! No matter what I tried I couldn't get a good contact with the side mounted battery posts -there is a very small post bolt that protrudes out -but barely -and the clip I had would just keep sliding off -let alone there was hardly a good contact anyway. After 10 minutes of trying, I gave up and called AAA.
The AAA guy had something I've never seen before; they looked like 2 long metal slides that he pushed in between each battery post and connector bolt that stuck straight up. He then was very easily able to attach two (large) clips from a battery jump starter and I had the engine up and running in no time at all.
Of course now I could kick myself as I didn't ask him what these "metal slides" were called. They would seem to be excellent to have for just such a situation (though the only thing I didn't care for is that neither one was insulated so I wouldn't want them flopping around and touching each other!) I did go online and found battery extender connectors that screw into your existing post, but the problem with these is that you'd have to install and leave them there (with a now slightly protruding positive post that doesn't have a protective cover which I don't like the idea of) -and I do like the idea of these "metal slides" that can be kept with the battery charger and used with any car that needs it.
So.... anybody have similar issues? What did you do? Does anyone know the official name for these "metal slides"?
2007 Saturn Aura XE 3.5 L LZ4 V6
2002 Saturn SL2 1.9L (manual)
Nigey is offline   Reply With Quote
Old 11-25-2021, 01:29 AM   #2
Greg1
Greg1's Avatar
1997 SW2
Default Re: Jumper cables on a 2002 sl2 Saturn battery.... stupid question?
I did a search on Amazon for "side post battery jumper adapter" and found them sold as side terminal adapters.
97 SW2 5-Sp 372k
Old 11-25-2021, 09:02 AM   #3
trottida
trottida's Avatar
I think these are them but let me know if I'm wrong. Note in the second photo how you insert into the battery cable clamps to get a good connection. They don't go onto the battery but rather into the clamps then onto the battery.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 11-25-2021, 01:19 PM   #4
Nigey
2007 AURA XE
Ah, those be them -I think I'm going to invest in a pair! Excellent and thanks for the help. I tried googling on loads of different terms and just missed finding them.
Old 11-25-2021, 02:58 PM   #5
Some jumper cables have tangs like those built into them for GM batteries. probably cheaper now for those adapters but if you need new jumper cables in the future and still have a GM battery look for the extension tang on them.
example
Old 11-26-2021, 09:41 AM   #6
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
I installed these for my desulfation module.
I haven’t needed to jump it but it’s much bigger than the little 5/16” bolt head.
File Type: jpg EEDD0FFF-BA41-4EF2-8E0B-9F47FD6540B4.jpg (102.2 KB, 10 views)
Reversed jumper cables! SMOKE ampecsu S-Series General 5 12-09-2018 03:02 PM
Car starts when you jump start but when you remove jumper cables it will die vikasevan S-Series Tech 13 02-17-2017 11:07 PM
Reversed Jumper Cables - 2000 Saturn SL2 Automatic dylank S-Series Tech 40 03-03-2015 06:48 PM
Jumper cables reversed, white smoke, no start, HEEEELP Magilla S-Series Tech 41 06-14-2013 08:52 PM
2002 L300 stupid question time ftpolkman L-Series Tech 8 04-21-2009 10:34 PM
