Old 03-28-2008, 02:50 PM   #1
tacinc1
tacinc1 is on a distinguished road
Default Replaced VB, can elec. cause no reverse at all?
For this 2000 SL1 auto. tran. SOHC, I've put on 3 valve bodies and two
input shaft nuts. It is perfect in forward gears. Had reverse slam before I started. Did Wolfmans fix etc... No reverse. Someone said that I should have reverse even if the elec. connector on top of the valve body was unpluged. Or can the wires on the disc on side of the tran. under the brake fluid or the selector disc it's self cause a no reverse? Tks....
tacinc1 is offline   Reply With Quote
Elec Rear Lights ragpicker S-Series General 6 09-27-2009 07:15 PM
Elec Window probs now PlainSC1 S-Series Tech 8 12-28-2008 01:04 PM
Replaced shifter cables , now no reverse Rick51 S-Series Tech 6 06-06-2008 04:34 PM
Answer to elec. for valve body/no reverse.. tacinc1 S-Series Tech 0 03-28-2008 10:49 PM
Can elec. prob. cause no reverse cond.? tacinc1 S-Series Tech 6 03-28-2008 02:05 AM
