Old 04-04-2021, 09:16 PM   #1
Upstate Saturn
Upstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really niceUpstate Saturn is just really nice
Upstate Saturn's Avatar
2001 SL2
Default Check engine light staying on for a noticeable few seconds after starting
My 2001 SL2 just started a new and alarming behavior. When I start her, the red check engine light stays on for a few more seconds after all the other dash starting lights have gone off. It's a noticeable length of time, at least for a hyper-alert Saturn owner like myself.
The oil level is fine, and the oil was changed about 500 miles ago. Do you think that the oil pump is failing, and if so, is there any other way to check it? Does this seem like a catastrophic failure waiting to happen, or am I just paranoid?
She has about 290,000 miles on her, and I had a remanufactered motor put in at 228,000 miles. I'm 99% sure the oil pump was replaced then as I had most pumps, etc. replaced while the engine was out of the car.
2001 SL2 manual - original owner - remanufactured engine at 228k miles, December 2015
1992 SL1 manual - bought used in '93, totaled in '00 at 170k miles, drove it cross-country a lot!
Upstate Saturn is offline   Reply With Quote
Old 04-04-2021, 11:08 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Check engine light staying on for a noticeable few seconds after starting
Do you mean the red oil can light? Mine stays on for a bit.
https://youtu.be/EEeYtufQUOI
That is not affected by oil level - unless it is so low the pump starves for oil. It is just a pressure switch on the oil galley.
This does not sound very catastrophic to me.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 04-05-2021, 11:20 PM   #3
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
The pump may be bad but it could also be the pressure sender. The only way to know for sure would be to hook up a pressure gauge in place of the oil pressure sender. Then you could see exactly how long the car takes to build pressure, and how much of it. Doing that would be kinda pointless without a reference of what it should be, so hopefully someone else happens to know what the oil pressure should be.
97 SL2, auto, 123K miles
Old 04-07-2021, 08:42 AM   #4
Ricketts
Ricketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of light
2000 SC1
Mine did this 4 years ago - I was concerned but reading through many posts here it seems the oil pump is not prone to failure. I bit the bullet and replaced the oil pressure sending unit and it has been fine ever since.
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Failed Smog Check After Erasing Check Engine Light Code trench619 Ion General 9 05-01-2015 11:58 AM
Check Engine Light/Trouble Starting theCTgrower Astra Tech 10 04-03-2015 09:11 PM
stuck in park, check engine light, brake light flashing Wemble Ion General 8 02-08-2014 05:38 PM
1999 SL2 Dies 5 Seconds After Starting jedijohn82 S-Series Tech 19 04-14-2009 09:27 PM
Battery light turns on 30 seconds after starting car, failing alternator? phitchow L-Series General 4 08-14-2006 03:59 PM
